Sealed Beam Worklight Amperage
/ Sealed Beam Worklight Amperage #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Bought a 4 1/2" sealed beam worklight for the L4300 today. It's a 12 volt unit with a GE L4611 sealed beam lamp.
Nothing on or in the box indicates the lamp amperage or wattage requirement. The ohmmeter shows cold filament resistance at 0.5 ohms. This can't be correct as an operating resistance as the light would draw 24 amps /forums/images/graemlins/shocked.gif!
Anyone know what the operating current requirement of a 12 volt sealed beam lamp is? I suspect it's around 5 amps but don't know for sure.
Thanks.
Bob
/ Sealed Beam Worklight Amperage #2
Surely there is some making on the glass of the lamp that indicates the wattage of the lamp. I can find no reference to this model of GE Bulb and they can be all manner of wattage.
Look for embossed lettering that may tell the tale.
Is this a round sealed beam? John
Yes, John, it's round. It's a simple thing with the bulb sort of jammed into a rubber cup-like affair that serves as the housing. A single wire comes out of the back of the cup. A bracket riveted to the bottom of the cup serves as the electrical return.
I tried popping the bulb out of the cup to see what's on the back, but it wasn't going too well so I gave it up in favor of checking with the braintrust. I'll try it again. The L4611 bulb number came from the box; 'GE' is embossed in the center of the lens. ARRRGGGGHHH! Checked again, it's L4411 /forums/images/graemlins/blush.gif, my mistake. Sorry, 'nother Senior Moment /forums/images/graemlins/crazy.gif.
Thanks for taking time to check.
Bob
/ Sealed Beam Worklight Amperage #4
I believe those sealed beam bulbs are generally 55 watts which gives a current draw of 4.58 amps. Multiply this by the number of lights you hook up to get total current draw. Ex.. 3 work lights.. 4.58 * 3 = 13.74 amps. I guess they could come in 100 watt flavors in which the current draw for one light would be 8.3 amps. The equation for figuring out the current is:
Current = wattage / voltage.
in this case 55 watts/12 volts=4.58 amps
or
100 watts/12 volts = 8.3 amps
Dave
/ Sealed Beam Worklight Amperage #5
Bob, from GE web site the 4411 is a 35 watt bulb which would make it under 3 amps. Bill C
Thanks bill and billy. This thing isn't anything special so I'd be surprised if it's 100 watts. I've allowed for up to 5 amps, so I figure I'm good to go.
35 watts? Well that's even better /forums/images/graemlins/smirk.gif.
Bob
/ Sealed Beam Worklight Amperage #7
<font color="blue"> cold filament resistance at 0.5 ohms </font>
The resistance of the filament increases as it heats up. There will be a high inrush of current that will quickly fall off as the resistance increases.
/ Sealed Beam Worklight Amperage #8
Nice use of ohms law. /forums/images/graemlins/wink.gif
an easy way to remember is the "magic triangle"
P
E I
Where: p= watts, E = volts, I = amperage. Put your thumb over what you want to find. Example: to find amps, cover I and divide watts by volts. To get watts, multiply E by I, that simple!
Also works for
E
I R
Where: E= volts, I= amps and R = resistance. To find resistance, cover R and divide voltage by amperage. Even if my math doesnt work, this formula does. Hope this helps all. /forums/images/graemlins/grin.gif
You guys are GREAT. Since I've loosed my belt one notch I decided I cant eat any more crow, lol. Just thought that I'd save myself some heckling in the future. Franz
/ Sealed Beam Worklight Amperage #9
<font color="blue"> divide 12 by .5 and that should be 6 amps </font>
Now, do it on your calculator.....
12 divided by .5 equals 24 on mine /forums/images/graemlins/grin.gif
/ Sealed Beam Worklight Amperage #10
You know, something didnt look right about that post /forums/images/graemlins/frown.gif
/ Sealed Beam Worklight Amperage #11
Bob, as someone has pointed out, it's a 35watt bulb. Here's a little blurb on it:
* Sealed Beam Lamp.
* Direct OEM replacement.
* Heavy-duty construction.
* Trade No.: 4411
* Bulb Type: Par 36
* Volts: 12.8
* Rated Average Life Hours: 300
* Base: Screw
Happy New Year. John
Thanks again John. Guess we finally got this one nailed down. Now to bolt it on and light it up.
Bob
KOMATSU WA270 (A58214)
Deere 333E (A60462)
Deere 333E (A60462)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2006 CATERPILLAR D6N CRAWLER DOZER (A62129)
2006 CATERPILLAR...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Hydraulic Breaker Excavator Attachment (A60352)
Hydraulic Breaker...
