Sealed battery JD 4115 needed, HELP!
   / Sealed battery JD 4115 needed, HELP! #1
KevPH1
Vermilion Ohio
JD 4115 JD X300
The JD battery is venting acid/fumes causing damage to the battery and oil cooler area. I'ved cleaned and repainted the corrosive acid damage.
I,now, need Optima battery information to replace the JD factory upgraded battery to a sealed unit. I heard the battery case color indicates the intended battery use appication. What product number,case color, should I ask to replace my JD 4115 battery?
JD's factory upgrade battery just doesn't fix the problem!
HELP!!!
/forums/images/graemlins/confused.gif
   / Sealed battery JD 4115 needed, HELP! #2
I believe you will need a Yellow 51R
I appreciate the model number information offered. The Optima model, D51R and a longer set of (J) hold down bolts should give me a lasting solution.
Note, the new Optima battery is a little taller than the JD battery. Thanks Pete!
Kevin /forums/images/graemlins/laugh.gif
   / Sealed battery JD 4115 needed, HELP! #4
Where's the best place to get Optimas? My 955's "Strongbox" is looking a little peaked. /forums/images/graemlins/frown.gif
   / Sealed battery JD 4115 needed, HELP! #5
Lots of us have used Remy Battery
They have great service. Sure beats running all over and trying to make something fit...
   / Sealed battery JD 4115 needed, HELP! #6
Just a curious question - why do you suggest a yellow top? I thought a yellow was a deep cycle battery and should be used when it is to be fully drained before recharge. Is not the tractor also charging while operating?
   / Sealed battery JD 4115 needed, HELP! #7
Optima only makes the "51" size in a yellow top. True, it is deep cycle, but that doesn't matter to your tractor. Actually, it's a good match for JD green 'n yellow!! I also used Remy, they have the best prices around. My 4110 did not need longer J-bolts, can't speak for the 4115. Good luck, and don't wait a minute longer!
   / Sealed battery JD 4115 needed, HELP! #8
Koby's got it right. The literature I have says it is an excellent starter battery, as well.
   / Sealed battery JD 4115 needed, HELP! #9
I like the yellow top for tbn-ers especially. We are always seeing posts like " I just put a search beacon on my rops (I drilled it before welding!)"
Or, "Installing an inverter powered buzz welder..."
We NEED deep cycle batteries!!!! /forums/images/graemlins/grin.gif
(I actually am serious, even if the post examples are out there a little...)
   / Sealed battery JD 4115 needed, HELP! #10
Thanks guys. Remy it is. /forums/images/graemlins/laugh.gif
9055 (A48837)
9055 (A48837)
2014 FREIGHTLINER CORONADO (A48992)
2014 FREIGHTLINER...
BUYERS PREMIUM & PAYMENT TERMS (A45679)
BUYERS PREMIUM &...
2015 Nissan Quest Minivan (A48082)
2015 Nissan Quest...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
(1) Tire on Rim (A47164)
(1) Tire on Rim...
