Seal on PowerShuttle filter?????????
   / Seal on PowerShuttle filter????????? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I am in the process of changing every filter and fluid on my TN70A. One of these filters is the PowerShuttle filter. I got a new filter from www.messicks.com. Then read my owner’s manual and it talks about making sure the seal is oiled. But the new filter does not have a seal. I don't want to remove the filter and discover that I need a seal. I am in no hurry to change the filter. I want to make sure I do nit right. Not having a required seal would be a bad thing.
Bob
   / Seal on PowerShuttle filter????????? #2
There is an o-ring on the canister housing. No, the filter does not come with a new o-ring. I have changed dozens of PowerShuttle filters and never needed a new seal. Your results may vary. Should you have one on hand? If I tell you not to bother, you will rip the old one in two before you even get to see it. If you buy a new one, you won't need it.
   / Seal on PowerShuttle filter????????? #3
Give er' a shot Bob! If the O-ring does get destroyed take it along with you to a local bearing distributer. They can easily match it up and put you back in business, not to worry.
PS I'm still in need of that NH dealers name & phone number that you mentioned before vacation.
Sorry for the delay. I just tracked down the receipt. I paid 34.95 per 5 gallons of Hydro (not 33.00 as I first thought).
Milwaukee Tractor and Equipemtn, Inc
414-466-8950
http://www.milwaukeetractor.com/
Bob
Thanks, I just had to rip a seal, then have to stop what I am doing, drive to the dealer, find out they have to order the part, drive home, then drive back, then drive home, then find out it is the wrong O ring, drive back, order another one, drive back, and so on.
I will change it without fear!!!!!!!!!!!!!!!!!!!!!!! I will chnage the filter wiht no extra O ring on hand.
Bob
I did it with no problems! There is a small o-ring on the canister. Running fine x 2 hrs. Thanks for the help.
Bob
5ft Set of Disc Harrows (A51573)
5ft Set of Disc...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2006 CHEVROLET EXPRESS SERVICE VAN (A52577)
2006 CHEVROLET...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
