Seal kit for old gannon box cylinder
   / Seal kit for old gannon box cylinder #1
meadorr
sierra vista, az
case 580c
Hi. Having problems finding a seal kit for case 480ck hydraulic cylinder 13534-1 that connects to bottom of gannon box (actually operates the scarifier/ripper).
Haven't done all the measurements, but rod diameter is about 1 1/8 inches. Alternate cylinder ID is Garrison 42989. Any one know the detailed specs for this cylinder or the seal kit part number?
Thanks
In case anyone is interested, I found the part number for the seal kit (almost the same as the # for the actual cylinder): 13-543. Found it available directly at RDO Equip Co (was pointed to them from Wainroy Mfg, who makes the kit but doesn't sell directly to consumers). $50
   / Seal kit for old gannon box cylinder #3
Open this link to Case Construction for the 480CK. Case Construction King Wheel Tractor | CASE Construction | MyCNH US Store
One it opens scroll down towards the bottom it will show 3 different remote cylinders. Find the one that matches what you have. Select the cylinder and another page will open showing an exploded view of the cylinder and part numbers to the right. Scroll down through the parts listing to find the seals. Some will say part of cylinder seal kit with the part number. Copy and paste that seal kit number to Google and you should find numerous seal kits to match that number. The will be much less than Case wants for them. I've bought more than several seal kits for cylinders on my backhoe on my 480C and rebuilt them. Most came from a hydraulic supply company I just felt a little better ordering from a company that deals in hydraulics. So far all I've installed have held up well after 3-4 years of occasional use.
   / Seal kit for old gannon box cylinder #4
Case did not make the box scraper and therefore doesn't list the scarifier cylinder kit.
@meadorr, welcome to TBN!
That Gannon cylinder kit is what all Gannon box scraper cylinders and what the majority of Gannon top and tilt cylinders use
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
Black Steel Diamond Plate (A55758)
Black Steel...
Ford 8340 (A53317)
Ford 8340 (A53317)
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
