duffer
Platinum Member
One of my curl cylinders on the FEL developed a leak. Not bad, but noticeable. Took the cylinder to a mechanic that does a bunch of farm tractor work, and they didn't have a "kit" for it. He called a Mahindra dealer and that dealer said that Mahindra doesn't even offer a seal kit. You have to replace the seals/O-rings a piece at a time by matching them up with generic seals. Sounds crazy to me, but probably true, knowing how illogical some of the Mahindra processes are.
I stopped at another Mahindra dealer on the way home, and he told me the same thing. No seal kits available. Said "you have to replace the entire cylinder". (like **** I am!) I was able to find a "band-aid" O-ring at a big box store that is a temp fix. But I'd like to get a "real" set of O-rings and seals to have on hand. The 2nd dealer told me that CYN was the manufacturer of the cylinders for Mahindra. Looked on line but couldn't find them.
Any of you guys find a good source for seals and O-rings for the hydraulic cylinders?
Thanx!
Thanx!
