Seal kit for FEL curl cylinder (2538 and others(?))
   / Seal kit for FEL curl cylinder (2538 and others(?)) #1
duffer
Platinum Member
Aiken, SC
'16 Mahindra 2538
One of my curl cylinders on the FEL developed a leak. Not bad, but noticeable. Took the cylinder to a mechanic that does a bunch of farm tractor work, and they didn't have a "kit" for it. He called a Mahindra dealer and that dealer said that Mahindra doesn't even offer a seal kit. You have to replace the seals/O-rings a piece at a time by matching them up with generic seals. Sounds crazy to me, but probably true, knowing how illogical some of the Mahindra processes are.
I stopped at another Mahindra dealer on the way home, and he told me the same thing. No seal kits available. Said "you have to replace the entire cylinder". (like **** I am!) I was able to find a "band-aid" O-ring at a big box store that is a temp fix. But I'd like to get a "real" set of O-rings and seals to have on hand. The 2nd dealer told me that CYN was the manufacturer of the cylinders for Mahindra. Looked on line but couldn't find them.
Any of you guys find a good source for seals and O-rings for the hydraulic cylinders?
Thanx!
   / Seal kit for FEL curl cylinder (2538 and others(?)) #3
If you can, go to an hydraulic shop or as Rick said, just check sites like Hercules, Motion Industries.
Quite often, you can buy the seals individually for much cheaper than a OEM Seal kit, here in my country anyways.
I suggest going to an hydraulic shop, because there are so many varieties of seals, with minor changes between them but that can make a difference.
2004 Range Rover HSE SUV (A48082)
2004 Range Rover...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2016 Ford Escape SUV (A48082)
2016 Ford Escape...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
