seal for post hole digger
   / seal for post hole digger
I was able to get a seal today that seems to be working. The inside diameter was slightly smaller than the old seal, but I was able to get things back together.
One more question though. The post hole digger has a filler hole on top of the gear housing, though there is no hole to check the oil level. How full should the gearbox be filled with oil?
I stock a replacement seal 1-3/4" OD, 1-1/4" id, AND 1/4" thick, CR# 12364, they are $4.32 plus shipping which would be about $3.00. Looks like I have 20 in stock.
Thank you,
Brian Brooks - Brooks AG Parts
513-715-0532
I may order one of your seals to have a spare on hand. Thank you.
   / seal for post hole digger #13
75 per cent of pumkin houseing full , so you do fill it up complete and create unnesary pressure and blow gasket etc . Its also good to see from one of your pics your pto shaft cover protector looks in great shape . They should have a little chain on them to keep cover from spinning .
   / seal for post hole digger #14
Post hole digger seals take a beating. Use Corn Head grease from John Deere or look for polyurea EP #0 grease.
   / seal for post hole digger #15
I have had good luck with Cornhead grease on gearboxes. I have said before, they should come that way from the factory.
I used GL 1 90 Gear Oil 80W90 in the gearbox. So far the new seal seems to be working.
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Zero Turn Mower (A55853)
Zero Turn Mower...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
