Seafoam
   / Seafoam #1
jasonzee
farmtrac555
I had a can of that and put a little in the tank now it smokes me out I have to start it with the windows and door open! That will be the last time I use that in the tractor.
   / Seafoam #2
Never ever had that problem with Seafoam. Never used it in a tractor except a Gravely. Mostly used it on lawnmowers and small generator engines with carbs.
Ralph
   / Seafoam
I hope when I have to fuel up again its gone.
   / Seafoam #4
does it smell like Georgia?. sulfur/rotten egg smell?. I always smelled that going through there. possibly it affects/maybe cleans the converter?.
   / Seafoam #5
I've never used it in a tractor. I find it works really well in small engines for cleaning carburetors and keeping things running properly.
   / Seafoam #6
The smoke is normal. I've run some crazy heavy doses on small engines and hot soaked carbs several times. That creates a LOT of smoke but it clears up as soon as the SF is used up or when the tank is topped off.
   / Seafoam #7
It's probably doing the job intended and burning out the crap in the engine that shouldn't be there. But isn't there a different formula (can) for Diesel engines?
   / Seafoam #8
The original SF is made to use in gas and diesel fuels, or in the crankcase oil or either too.
   / Seafoam #9
I'm aware of that, but I've seen different cans on store shelves, different color labels. One may be Marine.
   / Seafoam #10
Big mistake. Use more and run the tractor hard till it clears up. The SF is doing it's job.....google "Decarb", read the process and then think about your situation and your current decision.
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2008 Ford F-550 11ft Flatbed Truck (A52377)
2008 Ford F-550...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
