Brady D
- Joined
- Oct 29, 2021
- Messages
- 215
- Location
- Southern Middle Tennessee
- Tractor
- Ford 1910, Case farmall 95, John Deere 317g
Has anyone used sea foam in the engine oil of a tractor
Thanks for the response I put some in the oil pan but I was wondering if it’s worth using it in the fuelWow a week and nobody ever replied to this?
I've used Seafoam, mainly to scrub the oil system clean, then to do an oil change on the engine. Gunk Motor Flush is also another alternative and cost wise works really well.
If you plan on doing the engine oil with a Seafoam flush, I would also recommend doing the top end to clean off the combustion chambers and piston head tops. Not sure of your machine brand. There are ways to Seafoam via the intake as it can vary from brand to brand.
How well does it clean carbon depositsActually i works GREEEAAAATTTT in diesel fuel. Use in the summer to keep the microbes from making sludge in the diesel. It doesn't take much either for a 5-gallon tank. Use in the winter as a gas/diesel de-icer too.
Project Farm on YouTube did Seafoam in a pickup. Seemed to help.Has anyone used sea foam in the engine oil of a tractor
As I just said, I used it in my outboard and spark plug examinations of piston tops shows no carbon to speak of....grey piston crowns but no scale.How well does it clean carbon deposits
