scv question
   / scv question #1
GaryK
NC
JD 4100 HST
I was looking at the parts explosion of a dual 2nd scv for the FEL on my 4100. There is a plate between the valve itself and the rear housing. The plate has two plugs on it, one at each end. Are these plugs pressure and and suction or are they controlled by the valve and thus would operate only with the joystick?
   / scv question #2
I know that the dscv for my 4310 has the fittings for the 3rd scv function. When you add the 3rd, you are getting the fittings to make the connections.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
