scv on joystick not raising the new autoconnect mower
   / scv on joystick not raising the new autoconnect mower #1
B3200
Erie Pa.
kubota b3200
I just got a new 6 ft. auto connect mower on my 3720 cab installed at the dealer, they delivered it today, it is plummed into the rear scv outlet, so im assuming that the button on the joy stick will make it go up and down, it's not moving it at all, i tried the switches on the side consol but that didn't do anything, the dealer must have had it working but I can't figure it out, (can't call the dealer till monday)
   / scv on joystick not raising the new autoconnect mower #2
Is the hose plugged in? I assume since it is plumbed to the 3rd SCV it plugs and and plugs so the third SCV can be used for other things. I would make sure the hose is plugged in well.
   / scv on joystick not raising the new autoconnect mower #3
There is a switch that "enables" the button on the joystick. I can't tell you which switch, but it will show it in your op manual. It is a 3 position switch. OFF-ON-ACTIVATE.
Thanks for responce, Yes, the hose is in all the way , I did play with the switch but maybe i didn't activate it?? i don't know, i'm reading the manual now, (left it at work, thats where im at now), also I thought hydraulic lines always needed a return line, this set up only has 1 line.
This stuff allways happens to me at 5:00 pm on a friday
   / scv on joystick not raising the new autoconnect mower #5
It's just a single acting cylinder...only 1 line.
after work today, I started the tractor , hit the switch, pressed the button and it worked, I thought I did that yesterday, but... maybe not,,, anyway its working now, thanks for the input
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
