SCUT tilt hydraulic link?
   / SCUT tilt hydraulic link? #1
Maddiecycle
Grass Valley, CA
LS MT122
Hi all, I have an LS MT122 looking to add top & tilt, to run off a diverter valve setup off the loader circuit.
Plenty of top links out there but not finding much in the way of a tilt (i.e. side link) for these subcompact tractors. Any ideas? Thanks!
   / SCUT tilt hydraulic link? #2
For my tilt cylinder I had to go to a hydraulic shop and they found one to order. I couldn't find anything online.
   / SCUT tilt hydraulic link? #3
I am guessing that Fit Rite will be the only place to get one?
And even then I do not have the dimensions for it, you would need to get the required dimensions so that I can build it to fit right.
If you would like to proceed, please fill out the contact page on the Fit Rite Hydraulics website.
   / SCUT tilt hydraulic link? #4
What some guys do is find the right size/stroke cylinder...then using the non adjustable lift arm ends...they cut off the existing ends from the cylinder and weld on the ends from the lift arm...getting the angles right...it's really not a difficult job...
...I have made several using this method...!
Good Luck...
   / SCUT tilt hydraulic link? #5
I'll recomend FitRite. Not the cheapest, but high quality & Mountain View Ranch stands behind his work.
   / SCUT tilt hydraulic link? #6
It's a little more difficult when the proper cylinder to be used is an odd stroke such as a 3",5", 7", 9", or 11" stroke. Yes it can be done with the even stroke lengths readily available, but that does not always get the optimum working length desired.
It's not that big of a deal when the strokes are longer, but when you have to use a 4" stroke cylinder for an application that should really have a 5" stroke, you just lost 20% of your capabilities.
I would say that the most common side link stroke that I use is a 5" cylinder. You don't just go to any of the readily available cylinder suppliers and get an odd stroke length off the shelf.:rolleyes:
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
