SCUT Service Life
   / SCUT Service Life #11
It depends on the Zero Turn. A zero turn will not freewheel down the slope, but it could slide if the tires lose traction. A good commercial zero turn with decent tires on it will go as far as a Kubota BX series will on a slope and it will (in my opinion) be less likely to tip over as it has a wider stance and lower center of gravity. Good tires are the key though.
Aaron Z
I agree...I hit one area that's pretty steep with my Deere Z920. I just have standard tires (whatever it came with when the previous owner first purchased it) on it. I do run relatively slow and stay off it when it's wet (including morning dew).
However, a ZTR is pretty much a one-purpose machine. I've seen ads for snow plow mounting, but I doubt that would be much good except for very light snows.
   / SCUT Service Life #12
That was my initial reason for asking about them. While that's probably true, everybody I talked to including those that use them all recommended against trying to use one on anything more than a moderate slope. I cut mine with an X-300, but I have the issue of sliding downhill with Turf tires and chains. Along with an older transmission with 1,000 hours, it just doesn't do well. It will climb, but it overs stresses the trans. Previous owner used to cut this hill with a JD 4020 with a trailing brush mower. He says he had ot do it uphill because the tractor would slide downhill. Obviously that a whole lot more weight than a SCUT. I'm hoping that a 1,500 pound machine with Ag tires and a strong transmission will both climb and descend in a controlled manner without sliding or tearing turf.
   / SCUT Service Life #13
Thanks for the quick replies. I'm not looking to compare based on capabilities, the SCUT is like a swiss army knife with everything I can use it for, which is why the SCUT is way ahead of the ZT option. I am hoping that service life will be the last nail in the coffin for the ZT. My yard isn't that big (2.5 acres) and I can't imagine mowing will take too long with the SCUT, plus a lot of it is at a 25 deg slope, so neither is going to travel at top speeds.
Safe bet a diesel scut will outlast even a commercial gas ztr.
I run 2 diesel ztr mowers and an L4060 tractor... I prefer diesels for longevity, reliability, torque, and easy fuel handling.
Since you mentioned a 25 deg slope, I use a walk behind mower on anything over about 20 degrees.... life is short enough.
   / SCUT Service Life #14
Pity the OP couldn’t see his way clear to tell us about the slope consideration component of his mowing needs. I’d say a SCUT with 4wd is the only reasonable option for him. Until this critical info came to light the responses lacked relevance because those posting lacked a critical element of the discussion.
   / SCUT Service Life #15
Yup, a 4WD SCUT is the tool for the job..
   / SCUT Service Life #16
OP stated he wanted "quicker mowing." The z-turn wins that contest hands-down. Tractors are slow, heavy (hard on your lawn), and you have to remove the FEL for tight spaces. OTOH if you need a tractor, get a tractor. If you want to reduce mowing time, how about reducing the size of your lawn? :)
As far as slopes, the OP mentions a 25-degree slope. Are you sure you don't mean a 25-percent slope? See chart below.
Some theoretical difference in engine life 20 years down the road seems an odd way to choose a machine. Get the right tool for the job.
   / SCUT Service Life #17
Based on that graphic, I'd say mine is 20 degrees, so the OP may be correct.
I drop about 20 feet over about 60 feet or so.
   / SCUT Service Life #18
But considering the limitations of operating conditions is not an odd way to choose a machine.
You are entitled to your opinions but the indicated slopes do not lend themselves to a zeroturn mower in my opinion.
   / SCUT Service Life #19
I have a Kubota Z turn and a BX and a JD riding mower. With my Z turn, I can mow 25deg slope going up and down. 20deg side to side but steering is tricky. Z turns are much faster mowers and can turn on a dime and mow tight spots. I went with a 42in gasser as I have about an acre to mow. I do wish it had better traction. Wet grass and turf tires will slide/spin some times. I know it is a luxury but having a dedicated mower and tractor is the way to go if you can swing it.
148in Roll Up Garage Door (A55852)
148in Roll Up...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 Ford F-550 Versalift Stamm ATR45N 40ft Bucket Truck (A55852)
2018 Ford F-550...
2022 Horizon Trailer (A55973)
2022 Horizon...
CHALLENGER MT525B TRACTOR (A57192)
CHALLENGER MT525B...
(INOP) 2007 POLARIS RANGER 500ETI RTV (A57192)
(INOP) 2007...
