Screwed up big time :mad
   / Screwed up big time :mad #21
Was your exhaust underwater "blowing bubbles in the bath tub"?
We are laughing with you and not at you. Not a good feeling, I am sure, to have your tractor partially submerged. Good luck on the retrieval.
   / Screwed up big time :mad #22
Oh brother, that looks stuck real good! Might need a power-washer to jet that guy out of the sand.
   / Screwed up big time :mad #24
This is a good reason to list your location. There might be someone with a bigger tractor reading this just down the road and does not know it who could pull it out in five minutes. When I was growing up we had a 3000 pound ditch witch that we stuck really bad on a regular basis (oilfield work) and often pulled it out with the frontend loader.
   / Screwed up big time :mad #25
That's EXACTLY what I was thinking MickeyDBC. But its so COOL now-a-days to remain anonymous. Well - best of luck.
   / Screwed up big time :mad #26
Look and see how many electrical components, starter, generator, relays etc are under water and make sure you get the water blown out or away from those before starting. A good pressure washing should take care of the mud. If you pressure wash stay away from the electrics with the high stream water jet.
   / Screwed up big time :mad #28
Not one to judge...
I would have called a wrecker service immediately and got it out...
They will have the ability to pull you out safely with no damage...
So what if it costs several hundred dollars...
It may sink further like RickB stated...
   / Screwed up big time :mad #29
   / Screwed up big time :mad #30
Cool? Never considered it cool. I believe it is being wise and a bit SAFER to remain anonymous now-a-days. ;)
What ever equipment the O.P. finally gets to get his tractor out of the creek bed, I would want something that would lift the tractor up a little before attempting to pull it straight out.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
MAGNUM LIGHT TOWER (A58216)
MAGNUM LIGHT TOWER...
2019 International DuraStar 4300 24ft. Box Truck (A56858)
2019 International...
