Screw in front tire, no air leaking, should I worry about it?
   / Screw in front tire, no air leaking, should I worry about it? #21
I came out of a service call in the spring and found my front Sierra tire flat. Found a tiny unexplained hole in the sidewall, close to the tread. Borrowed some shop air from the customer and put a tiny #4 screw in the hole. Tried to buy a mini patch kit off E-Bay but it turend out to be the regular size and I don't want to make the hole bigger. So the screw is still in there but I think those tires leak so badly on the rims, that the screw isn't even loosing air!
   / Screw in front tire, no air leaking, should I worry about it? #22
I’ve had good luck with a screw that was threaded in vs pushed sealing holes. My success rate with the diy plug kits working hasn’t been good. Virtually every one I’ve done has still had a tiny leak.
   / Screw in front tire, no air leaking, should I worry about it? #23
Some kind of plastic fine threaded wood type screw that reacts to contact cement, would be cool. I should run down to the patent office.
   / Screw in front tire, no air leaking, should I worry about it? #24
Driving back to my office in the company car, I heard the telltale click,click,click of something fairly large stuck in a tire. I stopped and found a 1/2 inch lag bolt with a hex head fully imbedded on one tire. I managed to make it to the tire repair place the company used. They pulled a 1/2 inch lag bolt out about 4 inches long. They said that wasn't the first one they had seen that day. Apparently someone had accidently dropped a box of them on the street.
   / Screw in front tire, no air leaking, should I worry about it? #25
I never leave anything stuck in a tire. I'd rather address it on my terms in the shop on concrete than somewhere on the road or in the timber. :)
I feel the same as Richard on this. I have RimGuard in my tires so if the nail/screw ever causes a problem it will be a mess. Maybe if I had a little sub-compact I would not be as ****, but my tires are way to big for me to handle.
Funny how buying a tire repair kit might be a decent solution...LOL Murphy is a *******.
   / Screw in front tire, no air leaking, should I worry about it? #26
A favourite joke of mine is to let the air out of someones tire, and take the biggest ugliest crooked nail I can find, grind it off on an angle and silly glue it onto their sidewall! Perfect for that WTF moment!
   / Screw in front tire, no air leaking, should I worry about it? #27
Bummer!!!! As my gang often says, "that'll leave a mark". :(
   / Screw in front tire, no air leaking, should I worry about it? #28
I carry a tire plug kit in my offroad buggy, and in my onroad truck, and in my Kubota tractor. Good, cheap insurance. :)
   / Screw in front tire, no air leaking, should I worry about it? #29
You need to find something to do with your time..... :)
   / Screw in front tire, no air leaking, should I worry about it? #30
My dad had a slow leak in his tire so he pulled a nail out, then he had a fast leak. He put some glue on the nail, inserted it back into the hole, and drove to town to have it fixed. I believe he bought a new set.
Years ago I realized most of my flats came in the last quarter of their tread life. Now I try not to run them down to the wear markers any longer. As cars move to the NO SPARE concept not milking them dry even makes more sense to me.
(13) NEW TRUSSES (A58376)
(13) NEW TRUSSES...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
2011 Kubota RTV500 (A57149)
2011 Kubota RTV500...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
