Screw down to check oil level or not?
   / Screw down to check oil level or not? #1
cliffblue
Mooringsport, La.
John Deere GT275 and 345
I have an older 345 and GT275 and other than the engine oil dip stick on the 275 having it written on it, I have the darndest time remembering wether or not to screw down the dip sticks on the 345 engine oil and both transmissions to check the levels. I just remember that they are not all the same. Petty stuff I know, but it aggravates me.
   / Screw down to check oil level or not? #2
Do you have the manuals? When you get the method identified put a mark on the dipstick to indicate which method is used.
I am lucky. All of mine want the stick screwed in.
   / Screw down to check oil level or not? #3
Main thing, either way, is to always have oil showing on the dip stick.
Not a biggy IMO if oil is checked and level monitored regularly.
I do have both owners and tech manual for the GT 275 but only the tech manual for the 345. I have looked pretty thoroughly for this info in it but can't find it.
   / Screw down to check oil level or not? #5
Leave them both loose to read the level ---- just set them on top of the fill tubes.
   / Screw down to check oil level or not? #7
Generally dip sticks that screw in are checked without screwing them in where as push in type are checked with the dip stick fully inserted.
   / Screw down to check oil level or not? #8
I can't remember the procedure for Kawasaki. But Briggs screws in to check. Kohler command engines sit on top of the threads, The courage threads down, and I think the new 7000 series and the confidant screw down. Tecumseh sits on top of the threads.
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
