screening dirt
/ screening dirt #1
RipTide
Dallas, GA
JD 4200
Has anyone ever built something to screen dirt that can be used with a FEL? I want an easy way to screen out rocks and debris.
Thanks
/ screening dirt #2
Click on the search function beside the main index. Search for rock screen under all posts. I really should learn how to give the link but for now, this is faster.
/ screening dirt #4
HERES MINE,Built it for under 50 bucks works great!
ALAN
/ screening dirt
Thanks for the tips. That was exactly what I was looking for. Now to get off the couch and build a dirt screen for myself.
/ screening dirt #6
I just built one myself. I used 2x6 to build a 5x7 box. I used hinges at the corner so I could break it down. I put 4x4 hardware cloth over it and lifted it up to 45deg. Works great! Not pretty though.
/ screening dirt #7
hey escavder,
I was wondering how far apart your boards are to let the dirt through and how long they are? thanks tim
/ screening dirt #8
TIM,
I went back through my posts and found it.I posted last august in the KUBOTA OWNER SECTION,a thread called BUILDING DIRT SCREEN BX 23.I have all my details there.I wish i was better on this computer ,and knew how to show it.To answer your question ,i tryed it at 2 inch spacing,but it didnt screen it fine enough for my liking,i ended up at 1 3/8 apart.
ALAN
/ screening dirt #9
thanks Alan
I will look it up Tim
/ screening dirt #10
All you need to do is strech a piece of wire mesh over a 2X4 frame and prop it up with legs. The size of the mesh will determin how fine the sift will be. The larger the screen the more vertical suports you use.
Linx UT357714T 14ft Trailer (A65640)
Linx UT357714T...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
Single Cedar Glider (A65583)
Single Cedar...
MIXING BUCKET (A62613)
