"Screeching" sound
   / "Screeching" sound #11
It is absolutely the relief valve. That's the way they sound. I was surprised too when mine first did it. They crack open at almost 5500 psi so it has a different sound than a typical 2500psi hydro relief. I don't believe that they are adjustable...At least there is no mention in the service manual about it. There are test ports to check the pressure with a 10,000 PSI gauge.
The procedure to check it is to put it in C range, then set the parking brake, rev to full throttle, then push the pedal. It should screech, and you take your reading. Repeat for reverse (2 separate relief valves, 2 test ports)
Are you in C range when you are doing this? I have a real hard time making mine relieve in B range, and darn near impossible in A range, but it will relieve at the drop of a hat in C range.
   / "Screeching" sound #12
He said the video example was in high gear, you may be onto something. :thumbsup:
Yes C Range. Do you have a 4000 series John Deere? I had an older 4310 (same as 3320 now) and also rented a 3320. Neither of them did this.
   / "Screeching" sound #14
I have 2 4720's they both do this and have since they were new, it's usually in high gear with a heavy load going up a hill, or starting out when I should be in mid range
   / "Screeching" sound #15
Yes , I have a 4720, which probably would do it worse than yours because it has more power to overwhelm the relief valve.
In my opinion, C range is not for doing any useful work, just transporting.
You could check the pressures if you think they may be weak. I did have the dealer check mine, and they were fine.
Update,
Dealer found hydro pressure to be at 3200psi from the factory. Spec is 2500psi. Checked and adjusted under warranty. No more screeching.
   / "Screeching" sound #17
Update,
Which pressure? The implement circuit is supposed to be 2500, but that doesn't have anything to do with the hydro tranny. The tranny circuit itself is set north of 5000psi.
Good question...the screech isn't there anymore at least when I checked it today.
set of 4 sailun 11R24.5 tires (A56435)
set of 4 sailun...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
378721 (A54865)
378721 (A54865)
2017 Ford (A55973)
2017 Ford (A55973)
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
