hhiibel
I have a 4320 with cab. This situation is hard to describe. It happens in any gear. I can be harrowing and suddenly a screeching rotational noise comes on from steering counsel or bottom of it. I push in clutch and still have the sound. I take it out of gear and still have the sound. I put the fwd/reverse tiller in neutral and still have sound. I turn it off, start it and no sound. It can then come right back (or not) when I go back to working harrow. A few days ago I adjusted the clutch pedal play for the first time ever and thought problem solved (the engage was nearly to the floor) but after about 4 hours of use over several days the sound came back. Same symptoms. This has been going on for about a year. It was very rare but now crops up frequently. I don't pto. When it first started I thought I was addressing it by adjusting the nut under the fwd/rev tiller. It seemed if nut was too loose or too tight I got the noise. Just before I adjusted the pedal play for the first time a few days ago, I couldn't get it to go away. It would come right back upon loading it after start up. So I really thought I'd scored when after adjusting the pedal I could loaded it and work and even overload to kill. But only got about 4 hours of bliss before it came back. I measured the play just now and it seems to have decreased to about 1/2 inch. So, I just now set it to about 1 inch again and haven't tried it yet. Is there a clutch inspection plate? Or where do I check gearbox fluid? Is there a gear drive cable on the fwd/rev tiller?
To recap, the noise is rotational screeching/gear-ish? Push in clutch, take out of gear, put in netrual (fwd/rev) still have sound. Turn off, start up no sound. Clutch works fine, fwd/rev works, gears work, I can drive it around any speed, any gear, no sound. Go back to putting a load on it and sound comes back (at some point).
