Scratched Hood on 3316
   / Scratched Hood on 3316 #1
randall57
oklahoma
3316 mahindra
Could someone help me decide if the scratches on the hood of my 3316 can be repaired by me or should I have a paint and body shop do it. " See attached pics " I know that scratches give the tractor "character" but let it happen after I have at least 25 hours on her. Any suggestions or advice would be appreciated. Thanks
   / Scratched Hood on 3316 #2
Looks a little like my 3316. I dropped a log out of bucket onto hood. ouch!! I don't think you can buff it out, to deep showing bare plastic. You should see my Kubota she has a permanent frown from too close a contact with a few trees. Makes her look bad for a small tractor. I put a brush guard on my 3316 and it's all that gets skinned up in confrontations with the elements. I see you have a brush guard. At least it won't rust. How good are you with a spray bomb? Other wise it's a pro.
Thanks for the info! I am not familiar with a spray bomb. Can you let me know what that is?
Thanks
   / Scratched Hood on 3316 #5
Those scratches appear very superficial. Try applying some rubbing compound to just the scuffed area. It may take applications. If you are happy with the results, wax the whole tractor, inside the hood, and as some fanatics do, go for the wheel wells.
I just did a complete polish job on my back hoe, and the tractor. I also washed the entire inside of the hood, making sure to thoroughly flush all of the dirt from the foam rubber cushion. When it dried I sprayed it with lemon Pledge. Easiest wax job I've ever done.
   / Scratched Hood on 3316 #8
Randall sorry you feel bad about the scar , but don't sweat the small stuff "COWBOY" my heart and forehead have bigger scars than that.
BTW : Nice tractor ! :thumbsup: and tractor sleeping quarters.
Boone
   / Scratched Hood on 3316 #9
Wash it, wax it and you will be good to go. I know that the scratches bother you now, but clean everything up and put her back to work. All will be good. ;) If you get it painted, it will NEVER be the same. :(
   / Scratched Hood on 3316 #10
Especially if you paint it blue like some guy I know...
Back on subject, I'd buff the hood out and not spend the $$ on paint right now. Wait until you do some serious damage, and we hope that never happens. You will still see the scratches some, but it will sure look better.
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2006 PETERBILT 379 MID-ROOF SLEEPER (A52472)
2006 PETERBILT 379...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52748)
2004 Capacity Yard...
