scraper / earthmover
/ scraper / earthmover #21
If you could get a 1" "scrape" in clay, yes it would take approximately the same effort. A box blade will float with the lay of the land and raise and lower with the hills and valleys. It will perform well in softer soils but try the same tool in clay and you are wasting your time, unless you rip first. Then it is a slow tedious process, moving only small amounts. This is where a dirt pan shines, but it takes a lot of power and traction to pull through clay.
/ scraper / earthmover #22
</font><font color="blue" class="small">( I understand your analogy but wouldn't it take the same effort to scrape 1" vs cutting 1"? )</font>
Cutting shallow, the dirt "breaks" or curls a lot more easily, and the ends of the blade aren't dragging as much as they are when cutting deeply.
/ scraper / earthmover #23
And the resistance to loading 3yds of dirt is harder than 1yd +/- a box blade holds. The dirt at the cutting edge has to displace the dirt behind it in the pan. 2ft to 10ft depending on machine and point of the loading cycle.
Dirt in a box only has to displace the dirt above it maybe 18-24 inches worth till it rolls over to the front.
/ scraper / earthmover #24
I'd love to have the 6 foot 3 yard clam style scraper even if I could only put 2 yards in it. Right now I load the dump trailer with 2+ yards and carry a 1/2 yard in the bucket to move dirt. It works but stopping to connect/disconnect and load the trailer eats a up a lot of time.
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A64556)
2018 Nissan Titan...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2025 Mounting Plate Skid Steer Attachment (A64553)
2025 Mounting...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
