Scrap the 3 in 1 blade GT2542
   / Scrap the 3 in 1 blade GT2542 #31
pearlmanz said:
1*By the way is it true you have to change the hydro transmission oil filter after 10 hours?
3*If so, don't you have to empty the transmission before doing so?
5* -Also how hard is it to get to the tranny oil filter?
I know the break in oil has to be changed at 10 hours, but
7*can not believe you would have to change the hydro filter after just 10 hours.
1*YES
3*Nope / you can do like I did simply unscrew the filter and let it flow. Makes a real mess and loses about 3 or 4 quarts of fluid.Might be a better idea to take the drain plug out and drain out about 4 quarts into a pan.
5*The 2554 wasn't hard to get to at all.
7*The first few hours is when cuttings shavings grit etc can result so you need to filter them out.
   / Scrap the 3 in 1 blade GT2542 #32
The initial 10 hour filter change is a precaution to remove any production debris from the hydrostatic system. This filter change goes back to the IH days with the Sunstrands, and is a good idea. Think about it... with those cheap sealed hydrostatic jobs on little LT's, you can't even change the filter, or the fluid!
The Cub 2500's are a big step above the, "maintenance free" throwaway girlie tractors- they are designed for people who want to maintain a machine properly to last a long time. If your mindset is that you don't want to maintain it and just push it to the curb in 8-10 years, buy any one of the colorful inexpensive LT's you can get anywhere.
-Fordlords-
   / Scrap the 3 in 1 blade GT2542 #33
pearlmanz said:
Jessh the fluid gushing out doesn't sound good.
I just hope I can get to it without a lot of problems or having to take the deck off
even if it supposed to be easy??? Thank you friend, The PMZ
I did
   / Scrap the 3 in 1 blade GT2542 #34
Northstar said:
Pearlmanz- Glad to hear your happy with the new 2542, I'm still waiting to try my 2544 out for the first time. Hopefully by next week. My 1*manual says to change the filter at 10,50 and every 100 hours after that but says nothing about a complete fluid change.
2*My dealer said to just change the filter and top off the fluid you loose.
1* & 2*I'm tempeted to just change both the fluid and the filer every 300 hours and forget this hassle.
SKID STEER ATTACHMENT SHREDDER (A58216)
SKID STEER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 JOHN DEERE 650K LGP CRAWLER DOZER (A52709)
2021 JOHN DEERE...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
1991 Ford L9000  2,000 Gallon Water Truck (A59213)
1991 Ford L9000...
