Scotts Mowre 16 HP
   / Scotts Mowre 16 HP #1
lucybell
pa
Scotts s-16
I have a Scott's 16 HP lawn tractor with a Hydro Automatic Transmission.
The mower started to make a cracking/squeky sound (hard to describe) when I engage the hydro to move forward or backward. The mower is very slow to respond, it will move, but makes that sound. Someone recommend that I changed the drive belt which I did , but it did not seem to help.
Can anyone recommed what to look for next.
Thanks
   / Scotts Mowre 16 HP #2
Sounds like the hydrostatic transmission failed. If it's one of the later models built by John Deere (later became their Sabre line) in the $900-1400 price range, it has one of the cheap TuffTorq hydro units, and these are prone to failure after a certain number of years. Some googling suggests it has the TuffTorq K-51. That tractor would be at least 14 years old by my recollection, or older, so you have probably reached end of life on the transmission (you're lucky -- some people burn out the transmission in 2-3 years). If the rest of the tractor is in good shape, I'd look into a transmission rebuild kit (generally $300-400), otherwise look into buying a new tractor.
   / Scotts Mowre 16 HP #3
Check the pulley on top oftransmission just replaced one also the input shaft easy and parts only 50 buchs just take your time not difficult
   / Scotts Mowre 16 HP #4
Welcome to the forum!
Hopefully, we can find the right answer for you.
UNUSED AGT MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED AGT MINI...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
