Scott's (John Deere) mower Issues
/ Scott's (John Deere) mower Issues #1
GatorDude
Raleigh
John Deere
I have a Scott's (made by John Deere) and I let it sit too long with gas so had a challenge to start. It would run briefly and quickl so figured it was a fuel issue.
It has a Koehler 16HP engine. I took the carb apart and it was extremely clean but did try to clean passages with carb cleaner. After the rebuild, itt finally started running but I am having a fuel delivery issue.
What I notice is the gas filter is empty so again a fuel issue. I remove the hose between the filter and tank and then gas will fill the filter. This works but what I do not see is any significant flow when it is running.
I am trying to under why it is not pulling fuel and then open the line and it flows. There is some siphon effect that does not seem to be working since the carb is pulling in the gas (meaning the float is working) until it is empty but no gas in come down from the tank.
I think I figured it out. It was the tank vent so now makes sense. The design has a recess around the cap that is an spill over that also goes into the vent so into the tank. Trash just built up and plugged the tiny slots.
/ Scott's (John Deere) mower Issues #3
That is a common problem glad you figured it out.
/ Scott's (John Deere) mower Issues #4
Darn it, happened to me... just not quick enough :) ...and in my own town!!!
/ Scott's (John Deere) mower Issues #5
The very good folks here at TractorbyNet also have a excellent lawn mower forum called most appropriately www.LawnmowerForum.com. Recommend it completely as a mower forum and information source. Try it!
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
Adams 16T Tender Body (A63689)
Adams 16T Tender...
2022 EZ-GO ELITE...
