Scored a John Deere 71 flex planter- need opinions / education
   / Scored a John Deere 71 flex planter- need opinions / education #11
You can download a manual from the Yetter website. You can get plates from Lincoln Ag in Nebraska. bjr
   / Scored a John Deere 71 flex planter- need opinions / education #12
That's a great find and seems like a good price to me. I've seen old planters in much rougher shape selling for more money.
It wouldn't take a whole lot of work to rig up a couple of markers to mount on the toolbar to create a small furrow that would show you where to run the center of your tractor on the next pass in order to have perfectly spaced rows.
Thanks guys, a few more questions if you don't mind.
1) I think I may need to replace the springs inside the housings that keep tension on the chain. One end attaches to the disk holding the 2 small tension sprockets and the other end is attached to a rivet in the housing. Do I need to replace the rivet if I replace the spring, or can I remove the old spring and hook the new spring on the same rivet?
1) on one of the units, I can tell the drive shaft that is attached to the foreword most sprocket is slightly warped and wobbles some when it rotates. I would like to replace it with a new true one. How do you remove it?
3) in reading an operators manual, I keep seeing references to a 2-1/2" tool bar. My tool bar (which is red, and I suspect not John Deere) is 2". I realize it will work, but is a 2-1/2" tool bar actually correct?
   / Scored a John Deere 71 flex planter- need opinions / education #14
I have a 2.5 toolbar on mine, but I don't think it matters, unless you are a deere collector. As for your mechanical questions, I'd just clean it up, lube it, and use it. Not like you are going to plant hundreds of acres with it.
   / Scored a John Deere 71 flex planter- need opinions / education #15
As to the insecticide boxes - I have heard that people use them for planting very small seed vegetables - I'm thinking carrots and radishes for example. I saw that in ads on eBay and also heard it from the guy I bought my later model Deere planter from. I have a large fertilizer hopper up front that side dresses I believe 2 inches to the side of the seed, and the insecticide boxes behind the seed boxes just like yours. Mine was cut from a 30 row Max-Emerge planter.
I removed the insecticide boxes today. From everything I read, I don't think I will ever need them. What amount on ($) do you think I can reasonably expect to get for them? Thanks
   / Scored a John Deere 71 flex planter- need opinions / education #17
Do you still have those insecticide boxes
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2015 CATERPILLAR  XQ30 GENERATOR (A58216)
2015 CATERPILLAR...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
