Scored a BH MPG720 Aerator
   / Scored a BH MPG720 Aerator #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I found this one on Craigslist. It's in pretty decent shape and all the tines are good. Hopefully it works pretty decent for the yard and horse pasture.
It's a little big for my L3800. I have my backhoe on the back right now, so I haven't been able to see how well it hooks up. The lift height could be an issue, but I think it will work out OK, I can modify it if I need to. For what I paid for it, I could turn around and sell it at no loss if I decided it's not what I want.
Here's my work buddy Mason, posing with it.
   / Scored a BH MPG720 Aerator #2
I have something similar I use on a New holland 1925 .....a 35 hp tractor . no problems at all
   / Scored a BH MPG720 Aerator #3
Nice:thumbsup:
   / Scored a BH MPG720 Aerator #5
gsganzer, how is the aerator working out for you?
Haven't had a chance to try it out yet. Too busy with other projects. I'll report back when I do.
   / Scored a BH MPG720 Aerator #7
If you don’t mind me asking what you have to give for it and how does it work?
I believe I paid $650 for it. I added about 600lbs of weight to it by casting (2) 300LB concrete blocks that fit in the weight tray on top. It works great. You certainly have to time it just right with the soil moisture to get the right penetration.
If I was only doing pastures, I might want something like an Aerway that causes a little more soil disruption. But this one works for my lawn too and the price was right.
   / Scored a BH MPG720 Aerator #9
Price was right, for sure. I have the same aerator. Spoons are available for it through sources other than Bush Hog and are easily replaced. I agree that the moisture content of the soil must be just right.
   / Scored a BH MPG720 Aerator #10
I have a toro 6 ft aerator that was used for fairways it weighs about 1300 lbs have no problem pulling it with L4600 kubota you should have no problems
IPad Air 64G (A56860)
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
High Accuracy Meter Fuel Pump (A57453)
High Accuracy...
2010 Honda Fit Passenger Car, VIN # JHMGE8G28AC003572 (A57453)
2010 Honda Fit...
