Scope slides off
/ Scope slides off #1
PhilNH5
Platinum Member
SE NH
Kubota B3000HSDCC
Folks,
A question for the gun owners. I have a Gamo pellet rifle with a 4x32 scope. The gun is usually stored upright in the corner of a closet. I noticed the scope going out of alignment and kept making adjustments. Then I noticed the cause - the scope slides down the mounting groves on the rifle. This takes weeks to happen. I remounted it in february and then marked the grooves so I can see it has moved.
Is there a product to prevent this? I really do not want to have to store the gun horizonally all the time unless I absolutely have to.
Thanks,
Phil
/ Scope slides off #2
I would think the problem would occur with recoil, not from standing unused. The mount for the scope on mine has set screws that hold it firm. What kind of mount are you using?
/ Scope slides off #3
Phil
Pellet rifles require special scopes that can absorb recoil in both directions. The mechanism in a pellet rifle causes the rifle to first recoil forwards and then recoil towards the rear. If the scope lenses are not designed and mounted to absorb recoil in both directions, the accuracy could be affected.
RonL
/ Scope slides off #4
Get a scope stop ( atually called a universal recoil stop), it fastens onto the mounting rail behind the scope. Attached is a picture of one and a site that sells them.
http://www.airgunexpress.com/ Go to mounts, then click on B-Square, it is the third item from the bottom.
/ Scope slides off
Wow, Thanks for help. I have a Bushnel 4x32 air rifle scope. The gun,scope and mounts came as a package from Cabelas so I assume it is all designed to work together.
I will order the "stop". Thanks for the link.
Phil
/ Scope slides off #6
Phil
I had the same problem with my gamo. It was also a package deal from Big 5 and I assumed it all should work together. I also tried the stop which stopped the rings from moving back. But then the scope started creeping back inside of the rings.
I visited some airgun sites and found out this is a common problem with springer airguns. It was recommened that I get some special airgun mounts/rings. I ended up getting some from BKL model 263 and have not had a problem yet.
BKL
J.D.
/ Scope slides off #7
Ron, could you eloborate a bit on the double recoil. I am having trouble visualizing how this happens, thanks in advance for your effort.
/ Scope slides off #8
Air is not stored in the rifle. When cocked, a spring is depressed. Upon pressing the trigger, the spring backed plunger "springs" forward, compressing the air which pushes the pellet out the barrel. Upon leaving the barrel, there is recoil similar to any other rifle.
One thing to help with mounting scopes is to ensure everything is spotless clean, that no oil or other substance is on the surfaces. This is true with any scope mounting, whether air gun or cartridge gun.
/ Scope slides off #9
I have also found that an extremely light coating of rubber cement or gasket sealant inside the rings helps everything stay put. Never had a problem with scope creep yet on a rig installed this way.
KBH Tender Trailer (A63688)
KBH Tender Trailer...
1975 Bomag MPH1 Soil Reclaimer Mixer (A61572)
1975 Bomag MPH1...
John Deere 8245R (A64119)
John Deere 8245R...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
