Schulte 21 spline pto shaft
   / Schulte 21 spline pto shaft #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Hi all,
Looking to purchase a used schulte blower
Does not have pto shaft, chute rotation set up nor three point frame
Can anyone tell me if the shaft is 1-3/8 21 spline? I counted 21 but did not have caliper with me to measure
Can I use an adapter to standard 6 spline an then use my tiller pto shaft?
I can make my own bracket for the three point and will make a rotation setup
Model is 7400
Thanks,
Joel
Thanks Baby Grand, I'm thinking that is basically what I'll go with.
Would anyone be able to confirm the 1-3/8 21 spline on the 7400 Schulte?
I'll call them this morning, I'm sure they can tell me.
It is a nice heavy built machine, looking forward to getting hooked up.
Would anyone have a manual? Or parts diagram? I'm going to have to build the three point bracket and any detailed pictures would be great, including the manual chute rotation, I think I'll go with the cable wrapped around a manual cranking shaft.
Thanks again Baby Grand,
Joel
   / Schulte 21 spline pto shaft #4
Joel
Joel,
I can't confirm the spline but if you are interested in some pictures of a crank operated cable chute rotator (which I've converted to hydraulic) check out my thread HERE.
Thank you 5picker.
I really appreciate the link, I was looking at it last night.
GREAT POST.
Thanks again for taking the time to post the link,
sincerely,
Joel
   / Schulte 21 spline pto shaft #6
21 splines usually indicates the blower has to run of 1000rpm input speed. adapting to 6 spline 540 will run the slower at basically half speed....
unless the input shaft on the blower is just 21 spline because thats how they made it....
you better double check
Thanks hanson
I noticed that in some other posts
The manufacturer states 540 pto speed
My tractor does both so I should be ok either way
Will speak with manufacturer to confirm 540, I saw the 540 speed in a PDF on the blower but will double check
Thanks,
Joel
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
