school me on a/c mini-splits please
   / school me on a/c mini-splits please #11
And another note: "It's not the heat, it's the humidity", as they used to say in the muggy midwest. A dehumidifier can be installed cheaply (one drain line, one wall plug) and can remove all kinds of water. Get that humidity low, and the temperature becomes much less critical.
That being said, we're probably gonna install a two-headed mini in our house, which was greatly expanded 15 years ago. The HVAC zones overlap ... never the best situation, as you cannot close off unused areas.
   / school me on a/c mini-splits please #12
I have an LG mini-split 18K BTU. The A/C shop wanted about 2K to install it so I installed it myself. I bought a vacuum pump and a digital vacuum gauge. The digital vacuum gauge is important, the analog ones will not show you how low the pressure is accurately enough and they really need to be down around 300-500 microns. It's important to get all the moisture out of the lines. If you don't the oil will react with the moisture to form an acid which will be circulated through out your closed A/C system and corrode the coil, compressor, and lines from the inside, meaning the unit will not last long. To determine the BTUs you need, you will have to do a heat load calculation. If you don't you'll probably be either over or under what you need. Under means it won't provide the heating or cooling you need. Over is not good either because it won't remove the humidity from the air and consumes more power. (However, Over is better than under since you can add a separate dehumidifier.) And as mentioned earlier, with its inverter it will adjust down to what is needed for cooling fairly efficiently but "right sized" is best and most efficient. "Rule of Thumb" is not a good plan for this, but you don't need "Manual J" calcs either, you can find heat load calcs on the i-net. I used a small pump and let it run most of the day to get down to 300 microns, then released the freon. It's been running 2.5 years now and only needed the filters cleaned and the coils cleaned.
My unit came precharged for 25' lines. I needed 22' so I put an S curve in to take up excess length so I would not have to adjust the freon charge. The most difficult part of the installation is holding the 35# inside unit up in the air while trying to get the 2 freon lines, 1 drain line, and electric cable thru a 2.5" hole in the wall - 2 senior citizens were doing this. I recommend 2 younger folks or assistance from a 3rd senior citizen. Otherwise, 1 person can install one of these units.
   / school me on a/c mini-splits please #13
Almost forgot...I got reversible units that also work as heat pumps on cool days.
Due to central air in the rest of the house humidity is pretty well controlled, as much as one can in muggy Mississippi.
I just finished mine this weekend. Here's my thoughts.
I bought the Pioneer 12000 BTU 208 volt from Amazon Prime at 708 bucks. I later found the same unit shipping from HighSeer in Miami Florida for around 100 bucks cheaper. Came from same place. The Rule of thumb was 12K for 500 sq ft.
I bought the snap together trim pieces from Amazon. Everything was included in kit.
I bought the Yellow jacket 60278 Flaring tool in order to cut my line down from the original 16 ft length. This could have been coiled up but the tool made it a one shot cutoff and reflare. It was pricey at 100+ bucks though. The Ebay listing showed being able to order the unit from HighSeer with assorted different lengths like 10,16,20 ft etc. Amazon didn't show that.
I used a 2 1/2" milwaukee hole saw to cut the hole in the wall.
My buddy has a Harbor Freight vacumn pump (80 bucks) and I bought a special adaptor that was needed for the Minisplit port (about 16 bucks, I think)
All in. it took me 4 hours to install. And that was with two or three beers "thinking bout it".
How's it work? My two car garage is insulated and 20X24 with 8 ft ceiling. Concrete floor. In Oklahoma it has hovered in the low to mid 90s. My wife makes glass jewelry in her "shop" there with two small kilns running frequently but not all day. It has maintained the temperature she wanted non stop. (I think 75). I set it at 60 just to see first night and it was able to make it. I measured the output coils temperature with my temp gun and it stays a steady 43-50 degrees. It does not make noise.
I have two of the Mr SLim units professionally installed in my seceond floor home and bought this based on the performance of those.
I will buy another for my shop and yet one more for the little guest cabin I'm beginning on now.
I've watched the electric meter and had her not turn the AC off so I can get a baseline though she does turn the temp up to 80 because it get's too "cold" in there sometimes from working directly in front of the output breeze. I can't see any difference in electricity being used than normal.
I'm a believer and won't buy anything different ever again.
Lenny
Thanks for the pointers, I had forgotten to add in a beer overhead charge for our son.
Thanks, I guess we'll call it 1 senior citizen (me) and 1 younger folk (our son) for the labor force. But thankfully he has ALL the tools and materials. He did an a/c valve replacement on our Jetta TDI and saved us hundreds.
And like I wrote, real life experience shows 8k is just a little small so I'll probably go for 10 to 12K.
TAG 24" EXCAVATOR BUCKET (A54756)
TAG 24" EXCAVATOR...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
23222 (A50323)
23222 (A50323)
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
2007 INTERNATIONAL 4300 SBA 4X2 DUMP TRUCK (A51406)
2007 INTERNATIONAL...
