School me about PTOs
/ School me about PTOs #1
2520tlh
Ok I am thinking about purchasing a B3030 or B7800 and looking at the differences. One that I see is the PTO function. They list the B7800 as live continuous and the B3030 as live independent. Whats the difference? Are there any other main differences between these two tractors other than position control and PTO operation? Thanks for the help! BTW, I was quoted 15500 for the B7800 with one rear remote and loader and 17400 for the B3030 with one rear remote and loader, both with R-4s.
Thad
/ School me about PTOs #2
I'll take a guess, though I'm not familiar with either of these models.
In the days of old, the PTO operating was dependent on the tractor being in gear (or neutral) with the clutch out. So it was tough to start mowing for instance as the tractor had to start moving as the PTO was spinning up. I think that was referred to as non-independent PTO or not a live PTO.
As technology got better, it was referred to as "Live PTO", meaning you could engage the PTO, bring it up to speed, then engage the ground drive.
My guess is these are advertising terms for a sophisticated "live PTO". I would think you could use any PTO implement exactly the same with either tractor.
Now I'll be quiet and let someone smarter'n'me give a good answer.
Ron
/ School me about PTOs #3
Go to this link:
TractorSmart home page
Then click on 'info' at the top and then click on 'Tractor Power Takeoff'.
/ School me about PTOs #4
Both tractors are basiclly the same tractor, motor, transmission
The 7800 has a different lift system for 3 point hitch.
The 3030 has no clutch where as the 7800 does
The 3030 has several neat little add on's
To answer your question both have continous PTO the 3030 has it own
clutch for engaging and disengaging, the 7800 you have to use the clutch
Put another way the 7800 is strip down version of the 3030, but still a
good and powerful tractor. Personally I would chose the 3030
Hope this helps
/ School me about PTOs #5
2520th,
I believe if you shop a few more dealers you can add a mower and a rear attachment for $2,000 more. I also would go with the 3030 if it's in your budget.
________________
B3030,403 ldr, 72MMM, RB, BB.
Hope this helps
I read the link above that N80 posted and it makes sense. You say the B7800 has a clutch? I am assuming that it is just for the PTO since its a hydro tranny tractor?? Or am I missing something? Thanks for the info. I am still leaning towards the B7800 just due to the $2000 difference.
I actually drove the B7800 around a little but didnt mess with the PTO any.
/ School me about PTOs #7
The clutch is a multifunction device.
I have a B7510HST (hydro tranny).
There's a start interlock on the clutch so you need to mash down on the clutch to start the engine.
You need to clutch to change HST ranges (high, low).
You need to clutch to engage/disengage the PTO.
/ School me about PTOs #8
[[I I read the link above that N80 posted and it makes sense. You say the B7800 has a clutch? I am assuming that it is just for the PTO since its a hydro tranny tractor?? Or am I missing something? Thanks for the info. I am still leaning towards the B7800 just due to the $2000 difference[/I].
I actually drove the B7800 around a little but didnt mess with the PTO any[/I].
The clutch on the B7800 is a real clutch, when pushed in it stops everything
it stops everything. The B3030 has no clutch the pto is engaged with a clutch for the pto only.
Also the B7800 does not come with a mid PTO, I think it can be added as
a option.
I also suggest go to your Kubota dealer and get bouchuer's(sp) for both
tractors. I have a B2910 very much like the B3030, I have used a B7800
and I perfer my tractor.
Both are great tractors for the money, it comes down to what do you want
one with a few more frills, or one that is the same, but is just basic.
A decision I went through just 2 years ago.
Thanks for the explaination. I understand now how its used. Anybody else have any pros/cons of the B7800/B3030?
Thanks
/ School me about PTOs #10
I have a B3030 and looked at both the B7800 and the B3030 before I bought in August of '05. I chose the B3030 for the Position Control, Telescoping Links on the 3PTH arms and the Pin Type sway bars versus the turnbuckles. The PTO was not a factor to me as I don't think it makes much difference. I have no complaints with the Independent PTO. I have a 60" MMM so I needed a mid PTO anyway. As I recall, at the time I bought there was less than a $1000 price increase from the B7800 to the B3030, but that included the mid-PTO. As the B3030 was a new model and the B7800 was a model that had been out a few years, having the latest model as well as the updated looks of the tractor were important to me so I chose the B3030. For the price difference, as long as I was spending more than $17,000 for the tractor, FEL and MMM, the $1000 difference was small compared to the extra features of the B3030. The B7800 owners on this forum all seem to like their tractors. I know that I would have always been nagged by the thought of the extra bells and whistles I could have had if I had only spent a few more dollars. It is a big decision so make sure you will be happy after you buy. It will cost a lot more to upgrade later if you decide you want the extra features. Good luck.
/ School me about PTOs #11
There are several differences between the two tractors, some larger than others.
Position control 3pt is one difference. This is worth half of the cost if you are planning to use your 3pt hitch for tasks frequently.
Pinned 3pt sway bars versus turnbuckles is another excellent difference and again is critically important if you are frequently hooking and unhooking from 3pt implements.
Extendable lift arms versus rigid is again another excellent difference and again is critical if using your 3pt a lot.
Mid PTO is only critical if you plan to use the tractor with a MMM or a front mounted PTO device. If you have no plans to do that, it becomes less important of course.
The independent PTO of the 3030 is not as important but it allows you to engage the PTO without bringing the tractor to a standstill. With the 7800 you will have to push in the clutch which will bring the tractor to a stop, prior to engaging the PTO. You can then engage the clutch which will start the implement spinning, then step on the HSD pedal for tractor movement.
Tilt steering wheel is important if you have more than one operator. My wife and I both will operate our B2910. She is 5'2" and I am 5'10". We definitely use the tilt wheel along with the telescoping feature that was available on our tractor.
This cost difference is only 11% of the total cost. Very small difference to me. Would you forgo AC, cloth seats, cruise control, power windows and stereo on your next car to save 11%??? ;)
/ School me about PTOs #12
2520th,
I paid $13200.for my 3030 folding rop and $3200. for the 403 Ldr. that's $1,000. better then your quote. I added a 72" MMM for $2800., Landpride box scraper for $575. and rear work light for $60., total $19835., 82 mile delivery no charge. This is not a boast, but it was the best price in the tri-state area, since I don't know where live you may also have the best price. I still think you can do at least $500. less.:D
I didn't like the looks of the 3030 when they first appeared, I was stuck on the 2910 with terrible lights,though the lights on the redesign are better you still can't see due to the loader.
This thread was about the p.t.o.'s wasn't it?:rolleyes:
Thanks for all the information. A real good post. I am still undecided. The place I got the quote is Mcallister Equipment in Indianapolis. I guess I will shop his prices a little. He said they are one of the biggest sellers of equipment in the country. Dunno....Anybody from the Indy area??
2008 Isuzu NPR Box Truck, VIN # 4KLB4B1U48J801742 (A65563)
2008 Isuzu NPR Box...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
