Sprayer schaben 3-pt MH-55 sprayer will not spray
   / schaben 3-pt MH-55 sprayer will not spray #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Have not used this sprayer for a few years so testing with water. Not sure water moving from strainer cup thru green/black hose to pump. no water out from black outlet hose. suggestions? thanks
   / schaben 3-pt MH-55 sprayer will not spray #2
I have a three point 55 gal sprayer, with a similar pump, and it is very bad at getting an airlock.
I need to rebuild the pump on mine.
   / schaben 3-pt MH-55 sprayer will not spray #3
Fill the tank with water to prime the pump. It needs to be at least half full to get enough head pressure.
   / schaben 3-pt MH-55 sprayer will not spray #4
Maybe try pressurizing tank a bit with air hose (into vent) to actually force water into pump to prime it....
Dale
   / schaben 3-pt MH-55 sprayer will not spray #5
Did you run it dry when you put it up or did you put RV antifreeze in it. If you ran it dry (no RV antifreeze), the rollers in the pump are stuck (rusted) and you need to take the pump apart and free the rollers. I always park mine with RV antifreeze in the pump. Keeps the rollers from hanging up. I have the same pump as you, different manufacturer of tan\k and spray heads
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
