mrmikey
Veteran Member
Just finished building a scarifier and attaching it to the ole tractor.
The angle that the pins attach to is 3 x 3 x 3/8, main frame is 3 x 3 x 1/4 tubing, the pipes that go thru for the teeth to go thru is 1 1/2 sch40, teeth are 1 1/2 dia, diagonal brace is 2 x 2 x 1/4, flat bar is 3 x 3/8.
The tray is for cement blocks for ballast, find them easier to work with that buckets or barrells. At 40 lbs each I've got 4 on my back blade it it works great.
I don't think she'll haul all 7 teeth thru really packed soil or a lot of roots, if not I can remove whatever teeth I have to as they're bolted in.
No comments on the painting, I wouldn't have bothered as I dispise paiting but my daughter always hassles me if I don't paint projects.
While I was making things I cobbled up a sway linkage. Sick and tired of the blade moving side to side.
Just some 1/4" chain and a couple of pad eyes I welded 5/8 bolts to to go thru the arms at the front and a couple of turnbuckles I had.
I made this over the winter.
It was a pain in the backside having to fasten the two torque chains as well as the lock sleeve on the pto pump, always seemed to be tight and semi-stuck. I removed the chains and the lock collar, drilled and bent a piece of 1/4" plate. Now the pump just slides on the pto shaft with no lock and I just drop the bolt thru the trailer hitch holes and I'm good to go.
.....Mike
.....Mike
