Scanner
/ Scanner #1
G1tech
Burton, new Brunswick, Canada
Kioti CK20 HST
I have a OBD2 scanner for my Ford Ranger and my Hyundai Accent, will this work for my Kioti CK20S HST? If not, where can i find an online repair, like the Alldata repair I have for my vehicles, for my tractor?.....If there is such a thing. Thanks in advance.
/ Scanner #3
No the scanner will not work on your tractor, or I don't thank, on any tractor, they are made for the particular emissions and other systems on automobiles after 1995 or so.
The best way to work on your tractor is to get the Kioti SERVICE MANUAL and PARTS MANUAL. That is, if you feel your are a decent mechanic.
Maybe I should have said the best way to diagnose/work on your tractor is to use this forum and it's SEARCH feature. Practically anything wrong, somebody else already had to deal with and it might be here.
Good luck and let us know how you make out.
Mike
/ Scanner
Thank You so much guys!! There is nothing wrong with my tractor, I just purchased it like 3 weeks ago. It only has 14 hours on it. I guess I should of said what I really wanted, which is of course the service manual, I was looking for a diagram of all the major grease points, as I have to grease them every 10 hours, which I don't mind doing, I've already done my front bucket grease points, all 16. I guess i should warn you guys, I am quite **** about doing maintenance on my vehicles, Ford Ranger and Hyundai Accent, both have AllData programs and Repair Solutions with OBD2 scanner programs,....well, you get the idea. Anyway, thanks for your help and great ideas and concerns, I will keep in mind that if something does (God forbid) go wrong, I will come here first. Best regards to you all, Thanks again, Take care.
Trev
Oh, I almost forgot, where can I find the service manual, either online or purchase....etc.
/ Scanner #5
Service manual and owner's manual available via your dealer. There is virtually nothing online as far as print data. Your OWNER'S manual will show you grease fitting locations.
/ Scanner #6
Yeah, the owners manual is good to have. I also recommend the repair manual and the parts manual.
18ft Premier Pontoon Boat with Trailer (A65579)
18ft Premier...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
Easy Lawn Hydro Seeder (A65579)
Easy Lawn Hydro...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
New/Unused ATS Hydraulic Shop Press (A65583)
New/Unused ATS...
