Scaled my duramax last night.
   / Scaled my duramax last night. #1
Ryan03
Platinum Member
Chardon Ohio
Farmtrac DTC270, Kubota G5200hydro, Honda recon 250, Suzuki King Quad 450 4x4, 2003 2500 DMax/Allison 4x4
On the way home from my parents last night I was driving past a truck stop with Cat certified scales. At the last minute I decided to pull in and scale my truck with me in it{230lbs} to get the axle weights. I had been wanting to do this for some time so that I could plug these weights into the tire manufacturer inflation tables to see what I should be inflating the tires to. The truck is a 2003 2500HD regular cab 4x4, DMax/Allison, 265 75 16 tires, a diamond plate bed tool box loaded with an assortment of chains, tow straps, ratchet straps, and four or five hitch receivers. It has a Meyer Ez Classic mount plow system, which means the head gear, pump and hitch stay on the truck. Finally I have 700lbs of plow counter weight in the bed and 3/4s of a tank of fuel.
The weights were as follows
Front axle 4,240lbs
Rear axle 3,780lbs
Total 8020 !!!!
I was very surprised to see how heavy I was, considering i weighed in without the plow blade installed which I am figuring will add another 650lbs [meyer ST 90]. This will put the total weight to a whopping 8,670lbs. This is only 530lbs away from my 9200lb GVWR, and the plow blade will put me about 100lbs over my 4800lbfront axle rating. Im guessing my truck weighs around 6300lbs minus the plow stuff, me, and all my junk. It is really something how much weight those little odds and ends most of us carry with us in our trucks add up to.
For the record, I could not find a Cooper inflation table online, but Michelin and Bridgestones called for right around 50psi front and 40psi rear. I put the tires pressure at 45psi rear and 55psi front just to be safe.
   / Scaled my duramax last night. #2
You running "E" rated tires?
Yes, they are E rated.
   / Scaled my duramax last night. #4
That is about right. My 05 Dmax 3500 srw 4x4 crew cab long bed was right at 7,000# with me and 2/3 tank of fuel.
Nothing else other than about a 50# tool kit and a tow Strap. Its GVWR was 9900#
In comparison my 04 F250 4x4 short bed diesel 4x4 was 7,500#. It has a 10,000# GVWR.
My 06 F350 4x4 srw diesel is 7,600# It has a 11,500# GVWR.
My 08 Nissan Titan 4x4 extened cab weighs 5,680#. Its GVWR is 7,000#.
Chris
   / Scaled my duramax last night. #5
Due to the leverage won't the actual weight on the front end be more than the weight of the plow?.....Mike
   / Scaled my duramax last night. #6
Ryan, what does the door sticker say for tire pressures? 55 and 45 psi seem low. My recommended pressures are 60 front and 70 rear. With nearly 2500 lbs per tire in the front, I think you need a bit more pressure. But I bet traction is pretty good.
   / Scaled my duramax last night. #7
I would never run my tires that low. With the plow on I would be running them 70-80. About max. And I would be carrying more ballast and running those rears almost max as well
   / Scaled my duramax last night. #8
THe E rated tires i run on my E350 list 80 rear 50 front
If i was plowing with a pickup and i new i had that much weight on the front i would up the PSI on the tires to carry the weight.
I had my trailer and van at the gravel yard about 4 weeks ago. was 11,000 n change empty with trailer. figure my trailer is like 3500lbs empty or that puts my van at 7500+. I ended up picking up 4200lbs of gravel. (i asked the loader guy for 2 ton)
   / Scaled my duramax last night. #9
Air pressure and proper wear on tires when unloaded is going to vary on tire manufacturer. I run Michelin ms2 and run 65 front and 62 rear to get proper wear.
I get fairly even wear at these pressures unloaded. Depending on the truck, air pressures could vary.
Of course this is what I run unloaded. Do what you need to be safe.
My door sticker states 60 psi front and 80 psi rear. This is for the stock size 245/75R16 tires. I have long since upgraded to a 265/75R16 tire, which can carry a little more weight. I currently have Cooper Discoverer AT3 tires in the 265 size, load range E. The max load stated on the side of the tire is 3,416lbs at 80psi. single. The GAWR on the rear is 6,084 according to the tag in the door jamb, and the front is 4,800. I never really thought about it before, but it is a little strange that the front and rear GAWR add up to 10,884, which is considerably more than the 9200lb GVWR. I am thinking that the factory states the tire pressures assuming each axle is loaded to 100% of the GAWR for liability purposes, when in fact in the real world most of the time the GAW is much lighter calling for a lower pressure to obtain maximum wear and traction. Here is a Bridgestone inflation table, http://www.trucktires.com/bridgestone/us_eng/load/load_pdf/loadTables.pdf scroll about 1/4 of the way down the page to the 265/75R16 to view the inflation table. Here is a link to a Michelin light truck inflation table, which reads in per axle weight rather than individual tire weight. http://www.google.com/url?sa=t&rct=...eEIKR18VOKjxY5Hg&bvm=bv.1355325884,bs.1,d.dmQ
2001 John Deere M665 (A50120)
2001 John Deere...
2008 Chevrolet Malibu Sedan (A51694)
2008 Chevrolet...
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
Miller Curbilder, Kohler Engine (A52384)
Miller Curbilder...
377789 (A51573)
377789 (A51573)
