Ryan03
Platinum Member
- Joined
- Feb 26, 2006
- Messages
- 657
- Location
- Chardon Ohio
- Tractor
- Farmtrac DTC270, Kubota G5200hydro, Honda recon 250, Suzuki King Quad 450 4x4, 2003 2500 DMax/Allison 4x4
On the way home from my parents last night I was driving past a truck stop with Cat certified scales. At the last minute I decided to pull in and scale my truck with me in it{230lbs} to get the axle weights. I had been wanting to do this for some time so that I could plug these weights into the tire manufacturer inflation tables to see what I should be inflating the tires to. The truck is a 2003 2500HD regular cab 4x4, DMax/Allison, 265 75 16 tires, a diamond plate bed tool box loaded with an assortment of chains, tow straps, ratchet straps, and four or five hitch receivers. It has a Meyer Ez Classic mount plow system, which means the head gear, pump and hitch stay on the truck. Finally I have 700lbs of plow counter weight in the bed and 3/4s of a tank of fuel.
The weights were as follows
Front axle 4,240lbs
Rear axle 3,780lbs
Total 8020 !!!!
I was very surprised to see how heavy I was, considering i weighed in without the plow blade installed which I am figuring will add another 650lbs [meyer ST 90]. This will put the total weight to a whopping 8,670lbs. This is only 530lbs away from my 9200lb GVWR, and the plow blade will put me about 100lbs over my 4800lbfront axle rating. Im guessing my truck weighs around 6300lbs minus the plow stuff, me, and all my junk. It is really something how much weight those little odds and ends most of us carry with us in our trucks add up to.
For the record, I could not find a Cooper inflation table online, but Michelin and Bridgestones called for right around 50psi front and 40psi rear. I put the tires pressure at 45psi rear and 55psi front just to be safe.
Front axle 4,240lbs
Rear axle 3,780lbs
Total 8020 !!!!
