Scale Cat Twenty Two Dozer Ride On For My Son
   / Scale Cat Twenty Two Dozer Ride On For My Son #41
Is that seat going to be suspended? Springs or only the inherent cushioning in the foam?
Looks great!
Nope, just 2" of foam.
I originally bought pulleys for flat belts (since I needed them to ride on the backside of the v-belt). They were a little wide and they are crowned in the center. So they didn't quite work how I wanted. So I had to make my own. Out of some scrap of course.
Started on the fuel tank. It's shorter than I want. Oh well. I'll sleep on it before I work on it any further.
And got the handles tack welded.
There really is a lot of crap in a small space.
I've been playing around with sheet metal lately. Way back, I first showed a trial of the fuel/oil tank. It was too straight. I wanted the top to have a little crown to it. Then the second tank I made, it was too short. I can't help it. I'm picky and I want things a certain way.
So this time, I used a digital angle finder and a little gauge. So I'd bend the center to 7 degrees then the outer edges (using the gauge to get the distance from the center even) to 68 degrees. If you notice that doesn't add up, it's because when I put the piece on the table between two clamped pieces of steel spaced 16 inches apart, I get a real nice, and consistent crown. It worked really well.
Here is the fuel/oil tank with one end welded on as well as the front grill surround.
When I laid them on top of each other, they matched up perfectly. I was very happy with they way they turned out this time. And when I mean this time, it wasn't without some failures before I used the angle finder and gauge. Good thing I have a bunch of scrap panels.
However, the next problem I ran into was the hood. I'm using 14 gauge sheet. It was free and nice and heavy duty. The tank was 7 inches wide and the grill is 4 inches wide. It bent fine. The hood....it's 19 inches long. And my bender just wasn't having any of that. I tried a few different things and it just wasn't working. And even if I got the bends, I still probably wouldn't be able to bow it to get that nice crown. I think I'm going to have to try something thinner. I'll go to Menards tomorrow to see if I can find a decent sheet of 18 gauge that I can try out.
As for the sprockets and idler wheels, I'm still waiting on the guy that's going to burn them out. He ordered a hi-def plasma cutter for his shop back in January. It's been delayed a few times but it's supposed to be in by June. I want it to be a nice cut and supposedly hi-def plasma cutters are close to laser. So I'm on hold until then.
   / Scale Cat Twenty Two Dozer Ride On For My Son #44
Great looking sheet metal work, and your redneck bender did a dam good job.
Where did you get the digital angle gauge?
   / Scale Cat Twenty Two Dozer Ride On For My Son #45
Show us your shop too. Here is an idea for your tracks made of radial tire with cut off sides.
   / Scale Cat Twenty Two Dozer Ride On For My Son #46
That is some beautiful work, well done.
   / Scale Cat Twenty Two Dozer Ride On For My Son #47
Nice. I use EMD Locomotives every day. After seeing your work on this project, I hope they put you in charge of designing the cabs on the new engines.
   / Scale Cat Twenty Two Dozer Ride On For My Son #48
From my recollection of some 65 years ago 2" of foam only would be pretty scale. I don't recall any springs. Of course my 'forgetter' is rather unreliable these days.
Harry K
   / Scale Cat Twenty Two Dozer Ride On For My Son #49
This is a very well designed and built project. I have a struck mini dozer lying in pieces in my garage and the quality does not come close to approaching this
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
2021 Ford F-450 (A55973)
2021 Ford F-450...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
