Scag STHM screeching noise and power loss
   / Scag STHM screeching noise and power loss #1
jkendt1989
Doylestown PA
Scag STHM
I was given a Scag STHM-23SV to mow my 1 acre lawn. This summer when I started it up I noticed that there was a loud screeching noise when under load and power loss.
The Scag is hydraulics to move forward and turn the wheels. I am 99% sure that it is hydraulics related.
When going up hills it is the worst. The screeching noise starts and the tractor has trouble moving forward (The actual engine does not bog down at all). This noise comes from the main box where all the hoses go to and then go to the wheels.
The reservoir tank only has about 2-3 inches of the oil in it when the engine is not running. Should I start there to make sure that it has enough oil to function the hydraulics?
Any other tips or idea's would be greatly appreciated!
Thanks again!
   / Scag STHM screeching noise and power loss #2
Yes, start with the fluid level. But with that said, if it were mine I would do a complete service on the unit before using it. Then you know that part is taken care of, and can troubleshoot from that point.
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2006 IC Corporation PB305 Bus (A56858)
2006 IC...
2160 (A58376)
2160 (A58376)
2013 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2013 GALYEAN 130...
2335 (A58376)
2335 (A58376)
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
