Scag STHM screeching noise and power loss
   / Scag STHM screeching noise and power loss #1
jkendt1989
Doylestown PA
Scag STHM
I was given a Scag STHM-23SV to mow my 1 acre lawn. This summer when I started it up I noticed that there was a loud screeching noise when under load and power loss.
The Scag is hydraulics to move forward and turn the wheels. I am 99% sure that it is hydraulics related.
When going up hills it is the worst. The screeching noise starts and the tractor has trouble moving forward (The actual engine does not bog down at all). This noise comes from the main box where all the hoses go to and then go to the wheels.
The reservoir tank only has about 2-3 inches of the oil in it when the engine is not running. Should I start there to make sure that it has enough oil to function the hydraulics?
Any other tips or idea's would be greatly appreciated!
Thanks again!
   / Scag STHM screeching noise and power loss #2
Yes, start with the fluid level. But with that said, if it were mine I would do a complete service on the unit before using it. Then you know that part is taken care of, and can troubleshoot from that point.
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
iDrive TDS-2010H...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2018 GENIE GS-1930...
