SC2450
   / SC2450 #1
mooisha1
jane lew , wv
yanmar sc2450
Hello everyone ! i have a sc2450 that i bought a 1 1/2 years ago. My dealer packed up and left without notice !! My tractor will not stay in high range for some reason. Nearest dealer now is 2 hours away. Hoping someone has a simple fix so i don't have to travel so far. Can hold it in high range and it does fine but it will not stay in on its own . Any ideas ???? Thanks
   / SC2450 #5
Had this happen to me before. There is a small holding spring in there that holds the range selector in place. If broken or missing, it will not stay in the selected range. Check the spring!
   / SC2450 #6
When I had my SC2400, I had an issue with the parking brake linkage jamming the hydro linkage, now and then, which wouldn't allow the tractor to go faster than a crawl. It didn't do it all the time but began to do it enough to make it hard to mow. So, I took it to the dealer and after checking it all over he said to come and get it because he found nothing wrong and the tractor was running fine. But, when I went to load it on the trailer it happened right in front of the dealer who then found the linkage to be hanging up. I don't know if this is your problem but it might be something to check.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
20711 (A50323)
20711 (A50323)
CONTACT INFO (A53084)
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
