Sc2400 won't start, just clicks
   / Sc2400 won't start, just clicks #1
Cayuga48
North Chesterfield, VA
Cub Cadet Yanmar
My Yanmar Sc2400 won't start. It was working fine, my 18 year old grandson took it out yesterday to chop up leaves, shut it down to add fuel and now it just clicks. I think its the starter solenoid but I'm not sure if there is a fix or just replace the whole starter. Any thoughts would be appreciated. Battery is fine, fully charged.
   / Sc2400 won't start, just clicks #2
First check all battery connections and where ground attaches to frame. Last time this happened to me I had my wife try to start it while I twisted on battery lugs. As soon as I twisted the positive cable the tractor started.
   / Sc2400 won't start, just clicks #3
While checking these connections check the starter mount bolts for tightness. They are how the starter gets ground to complete the circuit. Is there a jumper from the engine to the frame? Check it. Remove the connectors from the battery and clean them - inside and out. Is your battery fully charged?
   / Sc2400 won't start, just clicks #4
If it is the solenoid, and it's one of the can-type with the bakelite end with two copper bolts, you can take it apart, carefully tap out the square head copper bolts and turn them 180 degrees so that the uneroded part of the head contacts the plunger disc. Burnish all the electrical contacts up with a wire wheel. I did that when my forklift acted up and it was like a new starter.
If the starter was working just fine before this, chances are high that it's in the cable ends or a connection somewhere, solenoids usually get progressively worse.
   / Sc2400 won't start, just clicks #7
Battery is fully charged but what does the voltage drop to when you hit the key? <9 = weak (fully charged) battery.....Have you tried jumping it?
   / Sc2400 won't start, just clicks #8
I have to agree with the above, a fully charged battery doesn't mean it's good. And if the voltage drops dramatically after one start attempt, then it's probably bad.
   / Sc2400 won't start, just clicks #9
Check all the safety switches. Might also tap the starter solenoid a few times.
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A52748)
YOKOHAMA - GALAXY...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
