SC2400 Transmission filter
/ SC2400 Transmission filter #1
dlane
Cub Cadet sc2400
I'm looking for a comparable transmission filter that I can use on my SC2400. My dealer is too far away and doesn't stock the parts. I found a Fram oil filter for my oil change, but I can't cross reference the transmission filter. Has anybody found an appropriate Wix, Fram, or other available filter? Thank you.
/ SC2400 Transmission filter #2
Look for another dealer in your area, or call your dealer and have him ship you the filter.
I do not think you will find a hydo filter in a different brand.
/ SC2400 Transmission filter #3
I bought all my stuff online... My dealer also has a habbit of not having anything in stock when I need it. So, they no longer get my business.
Here is a link for the hydro filter:
R.F. Houtz & Son, Inc. - Product Display
Thank you for your suggestions. Through a lot of research, I was able to cross reference all of my filters to Wix filters (oil, air, hydraulic). Now I can pick them up at NAPA. Thanks again for your quick responses and the link.
/ SC2400 Transmission filter #5
You wouldn't happen to have the part numbers would you?
I will post them tomorrow after Church.
Here's what I found through cross referencing numbers.
Oil filter - Wix 51358, NAPA 3158.
Hydraulic filter - Wix 57103, NAPA 7103, Baldwin BT8499.
Air filter - Wix 46499, NAPA 6449, Donaldson P822686.
Hope this helps!
/ SC2400 Transmission filter #8
Hope this helps!
dlane,
Thanks for the info. I think you might have mistyped the Wix air Filter number. The reason being is that it looks like the 46499 is a flat type filter. The napa number is correct which would make the Wix number 46449.
According to this site
TruckNet® Drivers RoundTable • View topic - Carrier ComfortPro PC6000 "B" Service
It looks like the Fram CA9248 is a cross reference for the Air Filter.
Thanks again for the info.
You are correct! I mistyped the number. Thanks for the Fram number. I also have a Fram number for the oil filter - PH6017A.
/ SC2400 Transmission filter #10
You beat me to it, I was just looking at that also.
/ SC2400 Transmission filter #11
and the oil filter is a Baldwin B1400
/ SC2400 Transmission filter #12
Baldwin Napa Wix Donaldson
Oil Filter B1400 3158 51358
Hydralic BT8499 7103 57103
Air Filter Rs3715 6449 46449 PB22686
/ SC2400 Transmission filter #13
What kind of transmission oil did you or are you going to use? I'm getting the stuff ready to do my 50 hours next weekend.
Thanks
300 Gal Fuel Tank (A64127)
300 Gal Fuel Tank...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
