SC2400 Repair/Service manual
   / SC2400 Repair/Service manual #1
Will D
Belleville MI
Cub cadet Yanmar SC2400
I inadvertently twisted and broke a steel hydraulic tube (#1 off of the optional coupler on the lower right side of my tractor) and I need to order a new one from cub cadet. I tried online to enter my tractor model number at Yanmar and cub cadet to get the part number but nothing comes when I enter my tractor model number. Does anyone have a Service or Repair manual for this tractor, or can tell me what the part number is for this tube. Thanks:)
I was able to get a picture of the part I need but still no part number. Gonna try and attach what I found so far. on the second page of the document in figure 8, it is the upper B hydraulic line.
   / SC2400 Repair/Service manual #4
I broke the shift lever bracket that attaches to the High/Low shaft from the hydrostatic transmission on my Sc2400 Cub Cadet/Yanmar tractor. I've removed the alignment set screw but the bracket doesn't seem to want to come off the shaft. I don't want to break any thing inside the transmission.
I'd also like a IPB of the shift lever and related parts. I've repaired the handle a couple of times but I need to replace missing parts now.
   / SC2400 Repair/Service manual #6
Thanks. At least now I know what the part is called: 'sub shift lever', and the process for removing it is straight forward.
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
1270 (A50490)
1270 (A50490)
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
