Say, I know it's silly request but I need head torque sequence ....
   / Say, I know it's silly request but I need head torque sequence .... #1
raymix
Amos, Quebec
Massey Ferguson 35 diesel 4 cylinders
... on a Massey ferguson 35 4 cylinders diesel.
I have the manual shop which states to torque bolts from inward to outward. Sounds silly to me ( I like to work in a perfect way and that's deffo not the good way )
Anyone ? I need the correct way sequence , I think it has 22 bolts if i am right ( from memory , i am at home not at the garage) and i believe it's a Perkins motor.
   / Say, I know it's silly request but I need head torque sequence .... #2
In my younger day worked on a lot of machinery;ammonia, CO2, and freon compressors closest to engine heads. Some real big old stuff we had no manuals to go by. Our procedure then was to start in the middle and criss-cross from side to side. snug every thing up first then using a bolt torque standard chart proceeded to to torque in 3 steps working up to the chosen final torque. That gave even results across the head. Naturally we checked everything first to assure the head was true in all directions. Good old bluing technique as well as a straight edge were used. Sometimes had to have them surface ground to true-up. That procedure is consistent with the work we did having the manuals to guide us.
Ron
   / Say, I know it's silly request but I need head torque sequence .... #3
I was taught work in a spiral circle starting in the center. Seems to match most torqueing charts.
Thanks guys,
Yeah I did it in a circle pattern and retorque a second time to perfectly tight all the bolts.
Seems perfect now.
And yes, the head surface was ground-up to make sure it's even, we did check with a straight edge :)
All good, this old baby will be up and running again.
40ft Sea Container (A52384)
40ft Sea Container...
2014 Dodge 5500 4X4 Bucket Truck (A53473)
2014 Dodge 5500...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2018 Freightliner Day Cab, Detroit Diesel (A52384)
2018 Freightliner...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
