2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,472
I think the question was asked which brands of portabands are good ones. I didn't know Grizzly had one. The only ones I know of are Milwaukee and Porter Cable. Neither is cheap.
Farmerford; Mike D74T I would still be working on a 20" long cut in 2" steel said:They used Milwaukee bimetal blades cooled with wet saw cutting fluid from a garden sprayer. The project did use a LOT of blades. The saw ran at a slow cutting speed. Running a saw too fast produces the heat that kills the blades. MikeD74T
I have 4 types of metal cutting saws. Dewalt chop saw 14 in metal cutting blade ,90 carbide teeth , industrial hacksaw using 1 in blades. Dewalt sawzall, Milwaukee portaband. They all have their place. The 14 in metal cutting saw will cut most ferrous metal up to about 4 in. Cuts like butter with a smooth cut. I also have a plasma cutter that will cut 3/4 in and sever 1 1/2 in. It will cut any metal. I have also used a metal abrasive blade in my Stihl 760 cut off gas saw.
The sawzall is the most versatile.
The Dewalt chop saw is a regular wood saw with special blade?
Piloon:
What do these look like ? When I was looking for blades they said there was a special metal cutting blade for the skill saw but the spot on the wall was empty and they had no idea when any new ones would come in. Other places I called and asked about thought I was crazy wanting a metal blade for a skil saw!
A portaband is better for cutting thick metal. No vibration, and the weight of the saw helps with the cut, and that reduces fatigue.
Do you have a good Chop saw? I had trouble cutting heavy metal until I bought a good one. The sparks are an issue. But it cuts fast and cheap.
Broken blades on a portaband, can put you in the poor house, if your not careful using it.
