sawmills and milling ya own
   / sawmills and milling ya own #1
jdkid
Akaroa South Island ,New Zealand (about 1/2 way do
8350 valmet with 980SL FEL duels had a 150 Hp deutz just sold it 10 NOV 01
Hi ya's
has anyone got a sawmill or had wood milled ??if so what kind ,how good/bad .i'm looking at one for doing boards for stock yards and also some gates most of the trees are softwood ..any ideas would help
catch ya
JD Kid
   / sawmills and milling ya own #2
I would suggest you look up Woodmills1 and read some of his threads. Lots of information there. There are portable band mills, chainsaw mills, and mills that have small circular saws at 90 degrees, all that move through a log. Plenty of variety and cost, and some may work out for your needs.
   / sawmills and milling ya own #3
I have one. It's a Mobile Dimension Saw made by Mobile Manufacturing Copmany in Troutdale, Oregon. This is not a bandsaw type mill it is a rotary that has two horizontal edger baldes as well as the vertical main blade.
The basic mill will saw a board 4"thick by 12" wide. It will handle a log up to 48" in diameter, length is determined by the num,ber of sections of track.
There is a website where you can check out these machines, I beleive it is mobilemanufacturing.com. I have had mine for more than 20 years. It is truly a one man sawmill. The lumber produced, if you keep the teeth sharp will not vary more than 1/16" in width or thickness from end the end and from board to board.
I believe you will find it competive with the mid-range line of bandsaw mills.
Randy
   / sawmills and milling ya own #4
I have a norwood lumbermate that I have hade for a year now and it has served me well for personal use and some custom milling. As said before there is a big price difference between mills and like tractors a mill needs to suit your own needs and budget.
Hi ya's
i'm looking at maybe a peterson or lucas mill .there is another one made in new zealand by rimu with 2 blades set 90 degrees to each other so cuts boards in one pass..90% of the lumber would be used in stock yards but some maybe used if we addon to the house i'll look up the address ya have given me tho and see what i find out..
catch ya
JD Kid
   / sawmills and milling ya own #6
yes by all means look into all of the mills of each type to find the one that fits your need. they are avaliable in circle and band from a few thousand dollars to many many tens of thousands. also check out sawmill and wood lot magazine and www.forestryforum.com to help you decide. if you expect any production look into hydraulics for log handling or plan on a crane or grapple. However you can saw fair amounts with some of the smaller/personal mills and log handling is reduced for swing blade as you set up over the log. with chainsaw mills you can also saw on the log. I have a woodmizer HD-40 that loads the log onto the mill and untill this summer i cut without any other log handling machinery. i would buy logs, you will be amazed at how nice a pile a log trucker can make. you will also be amazed at how hard it is to get some logs to roll or how to move a log 2 foot along its length to line it up with your mill. i regularly cut 1000 bd ft, handle the slabs, and sticker stack the lumber in a days work. i am and will be a woodmizer cutter the company gives great support and they are in for the long haul. i do this part time, teach high school full time and yet cut 86,000 bd ft my best year. good luck, do the research and keep us posted.
Hi ya Woodmills
i had a feeling someone on here had a mill ,your name should have been a tip off.. i have surfed around abit and looked at some mills prob is alot are made in the USA or canada and are not exported to NZ i note there are alot more band type mills made in the usa than we see here .i should have some info from the mill makers i have spoken to in the post tomorrow i'll keep ya posted how i get on
catch ya
JD Kid
   / sawmills and milling ya own #8
i just went to woodmizer worldwide and found this:
new zeland woodmizer contact
PAUL AND HAZEL MARSHALL
Rosewill Valley Road: RD 4
Timaru, New Zealand
Tel: 64-3-688-2032
Fax: 64-3-688-7676
E-mail: P_Marshall@xtra.co.nz
hi ya
Thanks for that .i'll try him the name dose not ring any bells but i have not lived there for a long time (olds had a farm around there)
catch ya
JD Kid
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
UNUSED FUTURE 1 SHANK RIPPER (A57193)
UNUSED FUTURE 1...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
UNUSED PABREAK RGB240 - 84" ROCK GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
