Saw this on a truck - what is it for?
   / Saw this on a truck - what is it for? #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I saw this on a Duke Energy utility truck that had a large boom on the bed. Any idea what the hoses connected to the hubs are for?
(sorry if pic is upside down. not sure why that happened)
   / Saw this on a truck - what is it for? #2
Tire inflation system. You can control the tire pressure from the cab pretty much.
   / Saw this on a truck - what is it for? #3
tire inflation, allows the operator to increase or decrease tire pressure on the fly
   / Saw this on a truck - what is it for? #4
Yes, as the others said - changing the tyre pressure (on the fly, maybe?)
I see a lot of log trucks and trailers with these on them around my area. I assume that they drop the pressure on the muddy logging tracks and then put it back up for the sealed road trip to the mill.
   / Saw this on a truck - what is it for? #5
Yes, common to deflate when going off road. Nice to be able to do remotely if this is the set up.
   / Saw this on a truck - what is it for? #7
It seems like the hoses would get ripped off in the brush. I guess not.
   / Saw this on a truck - what is it for? #8
They are also for on-road safety. Low tire pressure on a truck combined with a heavy load can result in a blowout and a tragedy for the driver and nearby motorists.
If the tire can be topped off when pressure drops, it increases safety. Newer cars and now trucks have low tire pressure warning lights, even an audible alert.
   / Saw this on a truck - what is it for? #9
Does this mean there's no (Schrader) valve in the tire stem?
That a leak anywhere in the system flattens all the tires?
If so, you better not snag a hose on a branch.
   / Saw this on a truck - what is it for? #10
Common around here on the 3WD and 4WD fertilizer spreaders, drop the pressure when they are spreading in the paddocks.
Most are based on the Mercedes Unimog.
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2015 Chevrolet Equinox 2LT SUV (A50324)
2015 Chevrolet...
