Saw this in another forum..... RM blade stuck in rear tire!
   / Saw this in another forum..... RM blade stuck in rear tire! #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
I read a SC hunting forum and someone posted a thread that he was bush hogging at his hunt club this morning and one of the blades on his bush hog broke off and it was thrown into one of the rear tires! :eek: Scary!!
   / Saw this in another forum..... RM blade stuck in rear tire! #2
I guess he didn't check the blades and spindals before he went out. At least is was a tire and not a leg it stuck into.
   / Saw this in another forum..... RM blade stuck in rear tire! #3
I'm guilty of that also. I haven't checked the blades on my deck since I put it back on in April.
But then again, I'm just mowing my yard.
   / Saw this in another forum..... RM blade stuck in rear tire! #4
Glad no one was hurt thats the important thing.
I don't check my blades and spindles each time before I mow either, and don't plan to.
   / Saw this in another forum..... RM blade stuck in rear tire! #5
More scary when you find a thrwn blade and see how far it went after going thru the bushog skirt.
larry
   / Saw this in another forum..... RM blade stuck in rear tire! #6
Hey Kebo...I saw that one too. I log into the SC Hunting forum quite regularly and sometimes post.
   / Saw this in another forum..... RM blade stuck in rear tire! #7
A random occurance. Kinda like lightning. You don't lean against a steel tower during a thunderstorm, and you don't walk alongside a working rotary cutter. But there's not much else that can be done.
   / Saw this in another forum..... RM blade stuck in rear tire! #8
My dealer said he lost a blade once and it went thru both sides of his back tire and another 200 feet out thru the grass. The blade had broke at the pin. This is one of those things that you cant anticipate. A bushhog is not like an aircraft turbine that you inspect every time you use it and magnetic particle/dye penetrant test the blades at certain intervals. You just have to use caution and keep onlookers out of the area. I flinch every time I pass a roadside mower. Beyond danger of broken blade is the possibility of slinging some hidden trash at you.
Hydraulic 3" Water Pump (A50121)
Hydraulic 3" Water...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2018 GMC Savana (A50120)
2018 GMC Savana...
2016 Isuzu NPR-HD 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2024 Doosan DX140LCR Hydraulic Excavator (A50322)
2024 Doosan...
