Saw the RTV1100
   / Saw the RTV1100 #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
I went to the Kubota dealer today to pick up an umbrella and right out front where nobody could miss it, they had a shiny new RTV1100 I was surprised to see on this soon in this little podunk town. I walked over and checked it out, so tight you can hardly get the door shut, lots of room, fit and finish looked really good, course I could hardly see for the tears in my eyes. I like the way the fenders are mounted to the frame, not to the under side of the bed. MADE ME WANT ONE REALLY BAD, I'D SETTLE FOR A 900....... AAARRRRRRGGGGGGHHHHHHH.
   / Saw the RTV1100 #2
which models have the diesel in them?
   / Saw the RTV1100
The RTV 900 and the RTV 1100 are both diesel, and they are both three speed hydrostatic drive with rear differential that can be locked, the front differential does not lock. None of the Kubota UTV's are gas and none of them are belt drive
   / Saw the RTV1100 #4
Milkman,
You wouldn't be settling if you got the 900. Plus Kubota has good financing on that unit. Pull the trigger. We only go this way once and if you leave for the kids they will blow it anyway.:D :D
   / Saw the RTV1100 #5
Milkman,
Just do it & enjoy the rush. You are going to make yourself miserable at the rate you are going. I agree with mikeyd !!!!
   / Saw the RTV1100 #6
mikeyd said:
Milkman,
Yep, a great time to buy a RTV900...go for it!
   / Saw the RTV1100
I ordered an unbrella for a friend who has a B7500 and a Rhino 650, when we go to pick it up, we'll drive the 1100 and I'll check out the deals on the 900 then. They had the 900 in camo across the drive from the 1100 last time I was there, what a sight.:mad:
2011 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2011 GALYEAN 130...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2014 Freightliner 108SD Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
CAT Chassis Only (A59076)
CAT Chassis Only...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
