milkman
Elite Member
- Joined
- Sep 22, 2001
- Messages
- 3,629
- Tractor
- BX2200, BCS 735
When diesel was at $2.179, I decided to get a barrel of off road diesel and save some money. I took a clean 55 gal barrel to town and found that the JD dealer was the only place to get off road diesel. They gave me a key to the pump and a clipboard to write down the gal. and I proceeded to go out back and pump up 53 gal of colored fuel. When I went to pay, I found out that it was only $2.089 per gal. so I saved a whopping $4.77. Two days ago, I finally run that tank on the tractor down really low, so I filled it with the fuel from the barrel, five minutes into using the tractor, it started to sputter and loose RPM, finally caught and was ok for another twenty minutes of idling around unloading a trailer. Today, I start mowing some grass and started sputtering again, went to the house took off the MMM and changed the filter, reinstalled the MMM and fifteen minutes later, started dying again, back to the house and off with the mower. Went to town and got a filter for the pump on the barrel of "cheap" off road diesel cost $34 and change, picked up three more filters for the tractor. Installed the filter on the pump, took $13.00 worth of fitting to make that work, changed the filter on the tractor and drained all the fuel. Put in the last three gal of good diesel out of my can and then got online and ordered a Mr. Funnel, $17.99. Saved a lot of money on that deal. /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
