Save hard drive data questions....
/ Save hard drive data questions.... #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I have a Thermaltake "BlacX" thingy that is plugged into back of PC. I have a 3 TB hard drive in it. This has been my backup in case PC died. Well.....pc died. Meanwhile, wife rescued a 22 pound cat. Cat happened to walk beside desk, tangled his belly in the wires, pulled the Thermaltake off the desk, crashed to floor and now, my 3 TB disk might not be long for this world. (might have already left)
Going into PC, I started to copy files (old family pictures) over to a brand new 4 TB SSD external drive. Came home from work, many files moved but needed to hit enter to finish something, did so, screen cleared. I still have tons of stuff on 3TB drive.
Go into disk Management, 3TB shows "unknown", 2048 unallocated, not initialized. Right click to initialize, bullet is on "GPT", hit OK (also did this same with MBR selected. In both cases, get "Data error (cyclic redundancy check) error.
tried to run checkdsk but, no drive letter so can't mount the drive (unless I'm missing something)
Went on to run SFC / Scannow and again, though it worked, it wasn't working on the missing drive as best I can tell.
While in Disk Management, the disk has what appears to be a red circle with a + in it, reminds me of the Red Cross. Click Properties, "This device is working properly". Volumes: Disk 2, type unkonwn, status, not initialized. Volumes and capacity (bottom) are blank.
That's quick snapshot of where I am and what I've done. I have scanned photos (spent WEEKS and WEEKS scanning old photos from the late 1950's through today....)
I'm open to any ideas on how to retrieve.... I've stumbled onto some programs that say they can recover data even after formatting disk. (My understanding is when you reformat, it simply erases the first character in the name (or something), which then tells the system that space is usable.) I don't know how accurate that is but I've done anything yet.
Oh, turn the Thermaltake off/on, you can hear the disk spool up. Unplug the USB plug and it will beep when it's plugged back in, so to me, that suggests the computer "sees" something.
Any thoughts/help is appreciated!
/ Save hard drive data questions.... #2
In the distant past, I had good luck with a rutime software product "GetDataBack". (https://www.runtime.org/data-recovery-software.htm)
If you don't find a fix out there you may want to take a look at it.
They have a "try before you buy" policy. You do a free download, run it on your problem disk and see if it can find what you need during a "preview" of recoverable data. If things look good, you can buy a license, apply it to the running program and then save the recovered data to a new location. No need to do another scan first. It is not cheap, the current license price is $79, but it is a lifetime license with free updates.
If you are going to try the data recovery route, do as little with the bad drive as you possible. Any changes made on the drive can reduce the likelihood of successful recovery.
/ Save hard drive data questions.... #3
This is why a long time ago I stopped using only one drive for backup, I now use 2. Plus, clone all data to an old laptop though my network and critical data is also archived to a network drive. Yeah, over kill I know but drives fail, folks do not realize they only are good for so many read, write cycles and this includes flash devices and many of the new super fast hard drives.
Do as little as possible to the drive, last time, a long time ago, when I still used WinDoze and had a failure like this all my attempts to recover it only ended up corrupting the drive further. Naturally that caused almost all the data to be lost. I suggest finding someone with a Linux machine to see if it can read the data, that is what worked for me.
/ Save hard drive data questions.... #4
Bite the bullet and take both drives into a computer repair shop. They have many more tools and toys than is prudent for most of us to buy. I recently took a computer to a shop when the Windows 11 upgrade failed “ because my computer specs weren’t suitable for upgrading.” They successfully installed the new operating system.
/ Save hard drive data questions.... #5
For the future, consider cloud backup. Any day I turn on my PC it auto connects to the cloud and backs up recent files.
Been using one firm for years. Safe and convenient. When I replaced the PC took a few hours and everything on the old moved to the new. Even the file and app locations were identical.
/ Save hard drive data questions.... #6
I never liked the Thermaltake "BlacX" Drive Bays. Shut down computer.
Just unplug the thermaltake and install the 3tb HD directly to your PC. Any unused SATA port and power lead should work. You may have to go into the BIOS to turn on the port.
Start the computer back up and it should see the drive an assign a device id. Then check drive status. Settings > System > Storage > Advanced storage settings > Disks & volumes
Health Status.
If you get a good. Go back and see if you can find the files you are looking for. If you get an error, I would suggest taking the drive to a shop. Cause drive recover can get very complicated to describe all the steps and tools used. A good shop will have all those tools to work with.
A quick format can always be recovered if you have not written anything new. It just opens the sectors for re-write. A full format is not recoverable. Since its not using the old headers, its establishing new ones for the R/W heads. So the old data has been zeroed out.
I would suspect the Thermalake as the issue. Not the HD. The first thing a shop will do is image the entire drive. Using Clonezilla. Then look at this clone. If that didn't work then use something like Recuva on the original. But a good shop will call for permission to do this, on the original drive. Cause the first rule, is you don't mess with the original, unless it is entirely needed. AFTER they have an image, of the original. You haven't told us what your PC was or replacement PC and OS is. And this matters, if you want to DIY this.
/ Save hard drive data questions.... #7
If I'm understanding correctly, the work you have been doing is focused on retrieving data from your backup storage device. Depending on the nature of the PC problem, the PC hard drive might still be OK.
I purchased a fairly inexpensive device that allows you to connect a hard drive to it and then plug it into a USB port to view the data. That would involve opening up the PC to remove the hard drive.
If you don't feel like doing all that, I also think it wouldn't be that expensive to just take the PC into a PC shop.
/ Save hard drive data questions.... #8
The fact that the device failed after having gotten knocked on the floor probably rules out internal interface issues, and points to the HD itself.
I've never heard of this particular storage device, but Western Digital ones have their own internal OS (and drive format), which means the drive format is unlikely to be something Windows recognizes.
I'd lean towards bringing it into a local computer shop to at least have them assess it before you do something that might further corrupt it.
/ Save hard drive data questions.... #9
I don't know the status of your PC or why you thought it was failing.
There are a number of external hard drive adapters that you can get that will convert IDE or SATA drives to USB. It may allow you to pull the drive from your old PC and attach it to a new PC or laptop to transfer files as if it was any other flash drive or backup drive.
That won't necessarily fix a bad hard drive, but it could get the data off of a good drive in a bad device.
It will depend on whether you've encrypted the data on your PC. With the strongest encryption, the drive may be keyed specifically to your PC which may reduce recovery options.
I'm on the pathway to go to almost exclusive solid state drives (SSD). They tend to be faster than the old hard drives, and seem to be more durable, although there is always a risk of a catastrophic failure.
/ Save hard drive data questions.... #10
Thermaltake BlacX are not HDs. They are external docking devices with built in copy functions. You can use these to standalone clone one drive to another or use them as external drive BAYs. The drives themselves, are standard off the shelf, Hard and SSD SATA type drives you plug in to the slot/s of the BlacX. I dis-liked using them because they broke all the time. They broke if you sneazed at one.
The stand alone cloning function was never intuitive to me and doesn't give much info, aside from some LED lights, that never made any sense to me. And you got to get your sourse and target right the first time.
Using Live Clonezilla was way more understandable, and controlable. But it gives a new user too many options and the documentation is pretty bad. A shop has figured this out, using it everyday, to see how it worked and what options to use.
From the OP, I really need to know specifics to carry on. Was the drive doing anything when it dropped? If not doing anything, the head was parked. A two 1/2 feet of drop would rarely make a diff.
/ Save hard drive data questions.... #11
Send it to me (I'm in Huntsville, AL (so just down I-65 from you) :) I will recover what I can for you. Please include return shipping. I'm on SS so not a lot of spare cash lying around. :(
Oh, been working on and programming computers since 1977. First one was a 48k (yes, K) Apple II. :) No hard drives, not even a floppy disk drive available until it was almost a year old. Cassette tape drive wasn't so bad, though. Have many computer types and OS's available to me.
/ Save hard drive data questions.... #12
WHAT ON GODS GREEN EARTH DOES THIS HAVE TO DO WITH TRACTORS WHISKY TANGO FOXTROT !!!
/ Save hard drive data questions.... #13
People have more than one concern in their lives, usually. Someone is asking for help. Yes, it's "off-topic" but that's not a big deal.
/ Save hard drive data questions.... #14
It is posted in the Rural Living forum, wide open to questions like this. Neighbor helping neighbor. I keep tractor manuals and photos on my computer and occasionally need help. Lots of people on TBN have knowledge beyond tractors, as the replies indicate.
/ Save hard drive data questions.... #16
I use MS Office 365 and OneDrive for my storage. I get 1TB of OneDrive cloud storage which is plenty for me. Desktop and laptop both have SSD drives. My desktop, laptop, and the cloud storage stay in sync. Make a change on the desktop and when I boot up the laptop it syncs all changes from the last session. Since I don't travel much after retiring, I boot the laptop up occasionally just to sync files.
/ Save hard drive data questions.... #17
Maybe I'm missing something, but I don't see any need to "sync files". A couple desktops and a laptop, all used for different purposes, almost nothing common between them.
/ Save hard drive data questions.... #18
Basically, just have 3 or more copies of your important data on as many different media. I choose to make direct copies rather than use a backup program that may be incompatible (down the road) with whatever I'm using to restore them with.
/ Save hard drive data questions.... #19
If you wish to get technical about it, :) we should be keeping one back up in the computers hard drive system (NAS, etc), one separate from the computer, and one stored in another off-site location. With auto backups unattended. Three generations but that's a lot of hassle, money, and aggravation.
/ Save hard drive data questions.... #20
I would suggest remembering to try to use those backups before you need them, to make sure they cover what you think they are covering..., but yes a lot of work, and for around here due to earthquake and fire risks, the off-site probably needs to be hundreds of miles away. For work, it would get sent a couple of states east or the Midwest.
All the best,
Peter
